Author Topic: 75/5 restoration evaluation  (Read 118788 times)
Offline Alfetta
Re: 75/5 restoration evaluation
« Reply #30 on: December 09, 2025, 07:53:34 AM »
Working on rear fender fitment.  Here is concept if it is to swing with the rear wheel....
Still pondering this...  I like the look but i will have to fabricate us some fender stays... I think i need to define a seat and get a look at the complete package...
Offline faffi
« Reply #31 on: December 09, 2025, 08:03:54 AM »
I like the idea of it, because it can look cool, although I personally think a smooth fender following the arc of the wheel would look nicer than the formed stock plastic unit. It will also add unsprung weight, but not to a degree that it would influence my choice.
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline Alfetta
« Reply #32 on: December 20, 2025, 11:33:48 AM »
So rear fender fitted....  I can now install drive shaft and flexi boot then move on to the seat options...  But now comes my next rant ....   I was going to lube the u joint as it feels good gut lube is old. However this looks like another GERMAN gotcha.....   I looked at replacement shaft assemblies, but those are stupid priced. So I will have to bring off the original impact stakes and go from there......
Why....   I don't understand....  But so it goes....
Offline Alfetta
« Reply #33 on: September 11, 2026, 11:50:45 AM »
Front forks and wheel re-fitted.  Looking at seat options, found this one, what do you think ?
Offline nadab_sardar
« Reply #34 on: October 15, 2026, 06:34:43 AM »
Can't see the seat in your post, the image didn't come through on my end, so hard to say much about that specific one. For a 75/5 though, I'd lean toward something that keeps the long, flat stock profile, since the bike's lines are so simple that a lumpy or overly sculpted seat tends to stand out. Thin pan, modest padding, and a bit of a kick-up at the back looks right with that fender you've fitted.
If you can repost the pic or tell us who makes it and whether it's a stock-style or custom piece, people can give you a better opinion. Also worth checking the seat hinge and the clearance over the rear fender and shock tops before you commit.
