Author Topic: No red earl light  (Read 1339 times)
Offline bacongrease
No red earl light
« on: October 11, 2023, 07:32:58 PM »
  2004 Stone.....No oil light.  I suppose some problem near the dash. But where is the sender unit on the engine, just in case?  thanks,    :boozing:
Online John A
Re: No red earl light
« Reply #1 on: October 11, 2023, 08:21:05 PM »
It’s on the block in front of the left cylinder. Test the light by grounding the lead, you don’t need to disconnect it , just run a ground wire from its connector and light will come on for the switch is a grounding switch.
Offline bigbikerrick
« Reply #2 on: October 12, 2023, 09:48:56 AM »
If what John recommends does not illuminate the light, check the tiny little bulb in the dash. They can be "fiddgety".
Rick.
« Reply #3 on: October 12, 2023, 10:41:01 AM »
Stone's & Jackal's had a crappy bulb socket, I've swapped a few shorted ones.
Offline bacongrease
« Reply #4 on: October 14, 2023, 09:34:48 AM »
 Thank you for the replies.   :thumb:
BTW...since 60W can't be found around here......the drunk at the end of the bar sez just add a splash of 80-90W gear oil to the 50W.........?  ?   :popcorn:
« Reply #5 on: October 14, 2023, 12:17:45 PM »
Has to be Corn oil, works best.
Offline dguzzi
« Reply #6 on: October 15, 2023, 04:38:54 PM »
 Blend lightly!!  Its a shaken not stirred thing....
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline bacongrease
« Reply #7 on: October 15, 2023, 07:16:35 PM »
  The drunk at the other end of the bar, of course said EVOO.    :undecided:
 He must be a member here.    :embarrassed:
