Author Topic: NGC - automotive O2 sensors, universal or specific?  (Read 1589 times)
Offline brider
« on: November 05, 2023, 09:29:35 PM »
I need to replace the O2 sensors on my '93 Range Rover (getting a 45 code on the OBD1 display), but the Atlantic British parts are over $100 each (need 2), OR an NGK equivalent is only $29 each. The NGK has a bare 3-wire harness whereas the AB parts have an OEM plug. The shop that does the work will likely have to spice the left-side new part into the existing old-part harness, because as far as I can tell, the left-side plug is un-reachable unless you remove the entire intake assembly.
But anyway, I was harshed on my Range Rover forum for considering a non-British-source part for the "miniscule" difference in price, but I'm thinking if the interchange P/N's are compatible, and since the shop will have to cut the nice AB harness to splice it into the existing plug anyway, will the engine really care which pair of O2 sensors are installed? How do sensors operate anyway, and could the specs on the British part be different than on the NGK part such that the engine will suffer?
I've always had good luck with NGK products.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline 80CX100
Re: NGC - automotive O2 sensors, universal or specific?
« Reply #1 on: November 06, 2023, 11:36:43 AM »
     I know little about O2 sensors (all my bikes don't have them or they're disabled) so I didn't file the details away, but there has been recent discussions on V11Lemans on the benefits of replacing bikes equipped with oem MG O2 sensors,with a generic brand,possibly Bosch?
     Iirc these O2 sensors were not only cheaper,but their quicker reaction time & improved efficiency communicating with the ECU,resulted in much improved engine performance.
     How your Rover & sensors,NGK etc are set up & would run,idk.
     fwiw
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Online PeteS
« Reply #2 on: November 06, 2023, 01:01:27 PM »
Being three wire usually means its a heated sensor. No idea if time it takes to get up to operating temp could trigger an error. Being the, ahem, frugal type I would take a chance and get the bargain price model.
Offline brider
« Reply #3 on: November 06, 2023, 05:33:35 PM »
Thanks for the replies. Since posting, I've talked to others and the consensus is NGK products are reliable (my experience, too), and since the Interchange #'s seem to indicate compatibility, that's good enought for me.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
Offline s1120
« Reply #4 on: November 07, 2023, 03:52:13 AM »
No idea who makes the rover part, but most european sensors seem to be made but NGK or Bosch anyways. I would do it.. more so beacuse you need to splice it in anyway, so ne need for the right connector.
Paul B
Offline nbags
« Reply #5 on: November 07, 2023, 04:53:38 AM »
very specific the heater has different resistance.  connector wires in different cavity the only ones that may work would be a early single wire
