Author Topic: 1987 Cali II driveshaft  (Read 2237 times)
Offline snobear
  • 1980 1000SP, 2022 V85, 2012 DR650,
« on: November 07, 2023, 12:52:43 PM »
Couple of questions as I have not received my manual yet.  What is the driveshaft end clearance supposed to be.  As well the spline in the pic I assume should slide apart but this one is solid.  Just want to make sure before I go any further.
1980 1000SP
2022 V85
2012 DR 650
1997 BMW R1100R Hack
I do these things not to escape life but so life does not
escape me
Offline Don G
Re: 1987 Cali II driveshaft
« Reply #1 on: November 07, 2023, 01:44:26 PM »
That spline coupler should just slide apart, likely rusted together. Show it a bit of heat from a propane torch, grease well upon assembly. As far as end play in the shaft, I have never worried about that, make sure that the pinion nut is up tight and that there is a wee bit of backlash in the pinion shaft. DonG
Offline snobear
« Reply #2 on: November 07, 2023, 02:00:46 PM »
Thanks for the info, who knew there were two of us from Saskatchewan
1980 1000SP
2022 V85
2012 DR 650
escape me
Offline Don G
« Reply #3 on: November 07, 2023, 02:37:29 PM »
There may be a couple more, not many in such a large area. DonG
Offline snobear
« Reply #4 on: November 07, 2023, 05:01:09 PM »
Well the good  news is the coupling finally came apart, the bad news the spline on the pinion shaft and that end of the coupling are toast.  There was also a bit of spalling on the outer bearing probably due to only one of the three splines sliding freely.
So I will need a pinion shaft bearings and a coupling.  Can the pinion be installed wwith the current crown gear which looks like new or do they need to be a set?
1980 1000SP
2022 V85
2012 DR 650
escape me
Offline nc43bsa
« Reply #5 on: November 07, 2023, 05:21:18 PM »
General practice is that the ring and pinion are a set.  Mixing and matching invites problems.
1990 MilleGT
« Reply #6 on: November 07, 2023, 06:03:51 PM »
Sold in sets, matched to ea other.
Online John A
« Reply #7 on: November 07, 2023, 10:27:50 PM »
Do you have a pic of the toasted splines?
Offline snobear
« Reply #8 on: November 08, 2023, 08:20:23 AM »
1980 1000SP
2022 V85
2012 DR 650
escape me
Online John A
« Reply #9 on: November 08, 2023, 09:29:53 AM »
Easiest fix is to find another bevel box.
Offline bigbikerrick
« Reply #10 on: November 08, 2023, 10:08:44 AM »
And Driveshaft as well, by the look of those splines.
Rick D.
« Reply #11 on: November 08, 2023, 10:24:18 AM »
I'd be looking at the ujoint also, my Cal2 came apart at 35K mi but I pull a sidecar. My shaft & coupler looked just like yours, I also swapped rear drives.
Offline snobear
« Reply #12 on: November 08, 2023, 10:36:39 AM »
I ordered a ring and pinion set from MG Cycle as well as seals and bearings.  Looked for a replacement box but thought better to just rebuild as never sure what you get when buying a used box and they are hard to find I think.
The driveshaft has no wear at all.  The bad spline was just the pinion shaft and one end of the collar.
Universal joint is still nice and tight so should be good
1980 1000SP
2022 V85
2012 DR 650
escape me
Online John A
« Reply #13 on: November 08, 2023, 01:36:32 PM »
Do a search for Peter Ropers articles on rear drive boxes, there are two of them, I believe called Rear drive rant one and rear drive rant two.
Offline snobear
« Reply #14 on: November 08, 2023, 05:07:34 PM »
Very well explained process for shimming the box, thanks for the link
1980 1000SP
2022 V85
2012 DR 650
escape me
