Author Topic: automotive fuse quqlity  (Read 1066 times)
Offline 73 sport
« on: November 07, 2023, 05:50:41 PM »
    An extremely informative video on "Blade Fuse Quality" : On ,Google, "Automotive Fuses-Does the brand really matter?
Offline bigbikerrick
Re: automotive fuse quqlity
« Reply #1 on: November 07, 2023, 11:30:17 PM »
Wow,It sure does not pay to buy the cheap harbor freight fuses. We should buy Littlefuse, or Buss brand  fuses. I am guilty of owning a bunch of those cheapies. I am going to throw them all out and buy an assortment of brand name stuff.  My Dad used to say.... "Lo barato sale caro"  translates basically to "Cheap stuff cost you  more in the long run"
This is a prime example!  I bought some of the cheap imitation " VW type " fuses to fit the tonti fuse box, on e bay, and the metal ends were not pointed like they should be, to stay in the holders little holes. They were rounded,and would pop right out after a while.  Those are going in the trash as well.
thanks for the heads up.
Rick D.
Offline guzziart
« Reply #2 on: November 08, 2023, 06:37:29 AM »
Same goes for knock off Ty-raps, electrical tape, wire, wire connectors, bearings, seals, hardware & some tools...imho.
'72 CL350, '72 Eldo '87 LMIVSE, '91 CT70, '08 Wing, '23 v85 Travel
Offline guzzista
« Reply #3 on: November 08, 2023, 03:14:16 PM »
In regards to GBC fuses ( bullet ends,  aka Torpedo , common on older Guzzis as well as  older European cars) the change from ceramic to plastic, with the added bonus of clamping/ connection issues of old fuse boxes, can bring all kinds of grief. After working on a Porsche 356 many years ago, I  learned from the owner about using  glass Bussman GBC fuses .
Since then that is all I have purchased / installed and , of course making sure clamping contact at the fuse box is solid. No longer available at auto parts stores, they can be found on EBay.
« Last Edit: November 09, 2023, 02:18:19 AM by guzzista »
Offline wirespokes
« Reply #4 on: November 08, 2023, 11:54:37 PM »
Thanks for the heads-up! I also have a bag of cheapie 15 amp blade fuses. I wonder what they're actually good for - what amperage?
Now I wonder what's the lowest resistance I can measure with my meter - a hundredth of an ohm? I'll have to check.
