Convert carb adjustment question
Topic: Convert carb adjustment question (Read 1590 times)
bigbikerrick
73 Eldo, 98 V 11 ,12 Ural Gear Up, 76 Convert,
Location: Southeastern corner of Arizona, right next to "Old Mexico, and New Mexico"
November 09, 2023, 10:25:08 PM »
hello Folks, when adjusting the carburetors on a convert, as in carb balance, idle mixture, and idle speed, is it best to make those adjustments with the clutch pulled in, or with the clutch out,and the drag of the torque converter slipping on the engine? Or does it even matter? Of course when testing the higher speed carb balance the clutch has to be pulled in.
thanks
Rick D.
jkguzzi
Gosling
Re: Convert carb adjustment question
Reply #1 on:
November 10, 2023, 05:26:28 AM »
I never used the clutch on my Convert so the drive line was engaged when adjusting carbs. Never had a problem and always got the expected results.
chuck peterson
Reply #2 on:
November 10, 2023, 06:40:06 AM »
Brake on for idle and mixture..
Centerstand for full advance..
Never touched the clutch…
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Reply #3 on:
November 11, 2023, 10:38:48 PM »
Same like Chuck.
From the Deep Deep South out in left field. There are no stupid questions. There are however stupid people asking questions. 🤣, this includes me. 😉 Hawaii.
lazlokovacs
Reply #4 on:
November 12, 2023, 06:51:02 AM »
mine doesn't have a center-stand!!
haven't been brave enough to do the full advance yet
chuck peterson
Reply #5 on:
November 12, 2023, 08:32:00 AM »
TOMB has an interesting skid mark in his garage
I forgot the new front dampers and springs left the rear wheel a little close to the floor
“What’s that burning rubber smell?..” moving the forks up the triple tree solves the rear wheel clearance
It’s not that far into the rpm range before it’s at full advance
But you still can’t know what rpm it’s happening at…I kept nudging it to more advance until it starts to pink on the road test, then back off a hair
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
bigbikerrick
Reply #6 on:
November 12, 2023, 10:27:12 AM »
Regarding......."TOMB has an interesting skid mark in his garage
I forgot the new front dampers and springs left the rear wheel a little close to the floor "
HaHaHa, Been there, done that, when I had my Cal II automatic..... I not only had a big "skid mark" on my garage floor, but also a matching skid mark on my "tidy whities"!
Rick D.
Vecchio Lupo
Diplomatico Di Moto
Gosling
"sounds like me"
Reply #7 on:
November 12, 2023, 08:58:23 PM »
the manual has a 1-2-3 procedure that I ignored and had lots of problems.
#1 adjust valves
#2 set the timing/ adj points
#3 set carbs
do yourself a favor and don't skip ahead to #3
Moto Guzzi "Going out of business since 1921"
Italian motorcycles are like Italian women,...sometimes they stab you for no reason.
RIP Harold "Dutch" Prattini ,...you taught me more than you know.
