Author Topic: Tank slappin’ California  (Read 6139 times)
Offline HarveyMushman
    • Photo Galleries
Re: Tank slappin’ California
« Reply #30 on: November 24, 2023, 04:19:37 PM »
I got the new BT46 mounted and balanced today.
This is how the shop found the rim strip:
Glad that's no longer in there. Reinstalled the wheel and managed a quick 20-mile ride this afternoon. It's definitely much improved. Steering is better and I could corner with more enthusiasm without a serious wobble. But I wouldn't call it stable, as I could still feel the wobble in there and I didn't feel confident with it. Will keep addressing the things mentioned here.
Tim
Offline lazlokovacs
« Reply #31 on: November 24, 2023, 05:21:34 PM »
My EV will get unstable when I take my hands off the bars.  And gets very much so when I load the rear luggage rack.
My cal vins were so heavy and planted that i could easily ride them with no hands, I had a mechanism for locking the throttle on long trip and I could go for miles without touching the bars if I wanted to. the footboards were all I needed to steer on the freeway.
Excluding a weave/wobble at around 80mph late model Calis should be absolutely planted on straights and leaned over.
Offline dguzzi
« Reply #32 on: November 25, 2023, 04:28:30 PM »
  But can you say what a late model is?  I think it varies on who you ask is all.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline lazlokovacs
« Reply #33 on: November 25, 2023, 04:34:38 PM »
I don't think I understand your question, but by 'late model' I'm referring to EVs and Vintages
« Reply #34 on: November 25, 2023, 05:18:22 PM »
I dropped my EV fork tripple trees 22mm and handles better. I have the stock soft rears that came on it new. It settles planted don't even need a steering stabilizer.
Tombstone windshield is never going to be aerodynamic. I'll bet head bearings have no grease & rusted cage.
« Last Edit: November 26, 2023, 10:29:12 AM by guzzisteve »
    • Photo Galleries
« Reply #35 on: November 25, 2023, 05:22:20 PM »
I dropped my EV forks 22mm and handles better. I have the stock soft rears that came on it new. It settles planted don't even need a steering stabilizer.
Yeah, maybe. But the bike generally seems pretty well lubed--there's lots of evidence of grease and other lubes applied where I'm sure Guzzi didn't.
Tim
« Reply #36 on: November 25, 2023, 06:56:28 PM »
If it's smooth & no play, run it.
« Reply #37 on: November 26, 2023, 12:07:18 AM »
Dropped ?
Offline s1120
« Reply #38 on: November 26, 2023, 05:58:24 AM »
I also had the wobble and weave like the OP, and once I adjusted the head bearings [90% of it..] and replaced the tires I was also stone stable. I too moved the fork tubes up the triples after that to quicken the steering a little bit, and even after its rock solid stable, and a little more... dont really want to use the word "flickable" but I guess more flickable would be what I mean..
Paul B
« Reply #39 on: November 26, 2023, 10:31:56 AM »
OK Huzo, fixed it. I wouldn't want anyone here confused.
Offline rustygman
« Reply #40 on: November 27, 2023, 02:42:30 PM »
I think Huzo has pretty much covered it all. One thing I didn't think of when I first got my Cali (1100i) and had similar issues was that the left and right fork were dialled on completely different settings. Seems obvious now but I missed it. Just saying.
Back on a Guzzi again. 1100i Cali.
Online Vagrant
« Reply #41 on: November 27, 2023, 05:02:07 PM »
Good point. Flush them out. On my 2001 Ev I was using 15 ounces of 15#. Set the adjusters both in dead center and turn each the same direction 1-2 clicks at a time. Worth a try.
Unlike Steve, I couldn't raise the forks more than 1/4" without the front getting too heavy.
