Author Topic: Conversion to dirt bike  (Read 3522 times)
Offline tris
« on: December 23, 2023, 08:58:20 AM »
Afternoon All
In about a months time, I will have retired and need some sort of project
I quite fancy a bit of green lane riding but the Roamer won't be too keen on that!!
I thought about a Yam XT250 but then thought that it would be nice to keep it in the Guzzi family
I need a shortish bike as I'm short in the leg
Would it be possible to convert a baby Breva into a gentle dirt bike.
Any good reference sites/books on what to look out for would be great
Cheers everyone,  I look forward to hearing your wisdom!!
1993 TW125 "POS" - Resting
Offline Perazzimx14
Re: Conversion to dirt bike
« Reply #1 on: December 23, 2023, 09:59:35 AM »
Fit some dirt-oriented tires., some dirt bike handlebars (I suggest CR High Bend) fashion a skid plate and have at it.
Limiting factors:
Cast wheels
17" from wheel
Ground clearance
Suspension travel
Weight
But unless you are Pol Tarres some light off pavement, you'll be fine.
If you want a much more enjoyable time, source a DRZ400 and think of it as a Mono-Guzzi. Lighter (at least 100lbs lighter than the Breva 750), longer suspension travel, 21" front wheel and much more pleasurable to ride once the pavement ends. Also cheap and easy to lower.
« Last Edit: December 23, 2023, 10:01:44 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline usedtobefast
« Reply #2 on: December 23, 2023, 11:16:49 AM »
Stornello?  I know nice used one might be hard to find, but should be much better than a Breva
2017 V7 iii Racer
2017 Griso
2016 Stornello
2000 Red Quota
Offline Perazzimx14
« Reply #3 on: December 23, 2023, 11:52:14 AM »
Not a whole lot of difference. They both well north if 400 pounds and the oil pans are hanging out the bottom of the bike exposed to every rock, log and pothole on the trail. The Stornello does have an 18" front wheel that is certainly better than the 17" of the Breva but tire choices are limited as its sort of a bastard size for a front and it's still not a great diameter wheel for off-road. The Stornello has a 5.2" and 4.4" suspension travel the Breva is 5.1" and 2.9". Neither are long legged.
Offline BoatDoc
« Reply #4 on: December 23, 2023, 12:20:07 PM »
I'm biased as I have a Stornello, but I think just the spoked wheels make it a better platform to start with than the Breva. I use mine for light offroad and modified it with Pivot Pegz, Barkbusters, longer throw Race Tech shocks (and the Race Tech emulators, which improved the front suspension but didn't change the throw). On the downside, the Stornello has ABS that can't be shut off (although I have pulled the fuse at times). Some have changed out the front tire for a 19-inch rim. As mentioned, there are not many dual sport tires that fit. I usually fit the 80/20-style Shinko 705 (4.1-18 front, 130/80-17 rear) which has great reviews and is inexpensive, although I bought a pair of 90/10  Bridgestone AX-41S to try when the current ones wear out.
With the modified Stornello I've done the MABDR and the ACT-Portugal and many other unpaved routes. The low, linear, power was nice. The bike is no lightweight, but it is over a hundred pounds lighter than the big adventure bikes!
I wonder if you could track down a mid-80s MG V65TT?
Have fun,
Paul
Offline Perazzimx14
« Reply #5 on: December 23, 2023, 01:28:49 PM »
Have fun,
Paul
No need to pull the fuse. Buy a inline fuse switch off Amazon for about $13 and you can turn the ABS on/off with the flip of a switch.
Offline tris
« Reply #6 on: December 23, 2023, 02:13:16 PM »
A V65 TT had crossed my mind
I'm still in the planning stage at the moment,  so should be fun getting a solution  :grin:
Offline BoatDoc
« Reply #7 on: December 23, 2023, 04:19:28 PM »
Thanks for the tip on the inline fuse switch. I had actually thought of that, but at the time (on a mountain trail), it wasn't possible. There is also the issue that the ABS sensor runs the speedo, so cutting power to that system also cuts the speedo and odometer. Still though, a switch would be more convenient than pulling the fuse for those moments on the trail.
Offline johnwesley
« Reply #8 on: December 23, 2023, 05:10:41 PM »
Michelin Anakee Adventure tires Come in a 18 front and matching rear which is as good of off road tire as the mentioned bikes. I’m working on an ev1100 scrambler and plan on the 80/20 Anakee tires
2003 cal ev custom build/ adv scrambler thing
2000 Quota
1989 cal III FF
1985 cal II
1977 T3 California
Offline Dr. Enzo Toma
« Reply #9 on: December 23, 2023, 06:03:15 PM »
My V7 850 handles forest service roads better than my Ducati Scrambler did. Neither are dirt bikes and both are heavy as sin for any technical riding where a proper dirt bike is desired.
MGNOC Member
« Reply #10 on: December 23, 2023, 07:39:37 PM »
Afternoon All
No reason you can't ride any bike on green lanes.  If they are dry, ride them as they are.  If you expect to encounter some softer terrain, then some 50/50 tires and you are good to go.
If you are just going to be exploring and not planning on seeing how fast you can ride, any bike will do.
I used to explore on a stock 1985 Honda Shadow 700, 1978 Honda 550 Four Supersport, and a 2011 Versys 650.  All with stock rubber.
Also used to drift a 1977 Yamaha XS750 on the sand at Daytona Beach, FL.
There are many videos on youtube of cruiser bikes riding off road.
https://www.youtube.com/watch?v=eO__iHWeLDU&t=181s
https://www.youtube.com/watch?v=Uz9dVfbsU8A
https://www.youtube.com/watch?v=W0LCTzEKdLg
Offline Perazzimx14
« Reply #11 on: December 24, 2023, 07:13:41 AM »
You can motocross a Goldwing if you want but that doesn't make it fun.
https://www.youtube.com/watch?v=EMrxee_fazo&pp=ygUSZ29sZHdpbmcgbW90b3Jjb3Nz
Online Moparnut72
« Reply #12 on: December 24, 2023, 09:32:57 AM »
There is a guy on utube doing off road on a Busa.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
« Reply #13 on: December 24, 2023, 01:51:43 PM »
That was fun to watch!
Online Pescatore
« Reply #14 on: December 24, 2023, 02:02:28 PM »
From your side of the pond you might find a V750 NTX.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline huub
« Reply #15 on: December 24, 2023, 04:24:07 PM »
if you can find one, get a V65TT, beside being a hooligan bike on tarmac , it makes a nice off roader
and with basically everything derived from the normal V65 they are cheap to own
