Author Topic: 1973 Eldorado Shift and foot controls  (Read 2471 times)
Offline Sprouty115
« on: December 27, 2023, 10:34:29 AM »
Hi,
As the title says I have a 1973 Eldorado.  It has Triple A floorboards with non-OEM shift and brake controls.  Everything functions as intended, but the controls look a bit too "unfinished" for me.
Shift Lever:
Brake Lever:
So now I'm wondering if I can replace them with OEM parts and still keep the floorboards?   My searches so far have led to a lot of different-looking parts and I'm a bit confused as to what may fit.
As an example here are two options for the brake lever:
Ebay Brake Lever:
(Description - No model listing)
(Description - Moto Guzzi 1974 850 T3 Rear Brake Pedal Lever w Linkage)
And here is a shifter I found...
Ebay Shift Lever:
(Description - shifter for Loop frames)
Any help would be appreciated...
« Last Edit: December 27, 2023, 10:39:22 AM by Sprouty115 »
Re: 1973 Eldorado Shift and foot controls
« Reply #1 on: December 27, 2023, 03:52:19 PM »
Hi,
Shift Lever:
Brake Lever:
Ebay Brake Lever:
Ebay Shift Lever:
The ebay long brake lever is from a civilian Ambo/Eldo. The T3 one could be from a T3 FB (footboard), Convert, or G5. That's not a Loop shift lever, looks much later - EV era. You'll likely need to make or alter linkage. The diameter of the pedal pivot on the Triple A brackets may be different that i.d. of the pedal bushings. Worth a try though.
I have a bunch of different footboard shift and brake pedals and could send them for you to try, send back what won't work, pay only shipping costs for what does.
Offline Sprouty115
« Reply #2 on: December 27, 2023, 07:20:57 PM »
Wow, that's a very generous offer!  I'll send you a PM to figure out the details.
« Last Edit: December 27, 2023, 07:25:44 PM by Sprouty115 »
Offline brider
« Reply #3 on: January 02, 2024, 06:24:58 PM »
Shift Lever:
Brake Lever:
Believe it or not, I'd be interested in your Triple-A controls (the shift/brake levers, but I'd consider the footboards, too if you needed them to go) if you decide to swap out to different ones. PM me if it gets to that point.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline Sprouty115
« Reply #4 on: January 02, 2024, 06:50:02 PM »
Will definitely keep you in the loop, it just may take awhile.
Offline Sprouty115
« Reply #5 on: November 03, 2026, 09:21:18 AM »
Hi Brider,
Tiple A footboards will be up for sale shortly, PM if interested (or sprouty115@gmail.com). No pressure either way.  (btw - tried to PM you twice, and neither message looks like it was sent)
Quote from: brider on January 02, 2024, 06:24:58 PM
