Whats with the push-pull rod going from the frame to the rear caliper mounting bracket??!! So, the bracket moves/pivots on the axle in unison with the rear frame?? I wonder how well that works as compared to the caliper bracket remaining stationary and moving in unision with the swing arm? Oh well, interesting complex project for 1st time Guzzista, good luck!Art
Hi All. Just picked up this neglected Le Mans CX100 and the prior owner was an engineer who loved to mod his bikes. He passed away around 15 years ago so I can't ask the original owner anymore so I am looking for information about the modifications done. Most interesting are the wheels and brakes. I have never seen a setup like this. The wheels are wider than the originals, forks stanchions measure the same as stock but the lowers are custom or had the brake caliper bosses shaved off and replaced by a mounting setup that consists of a plate that floats free of the lower fork leg and is anchored by the strut mounted to a bracket below the triple clamp. The rear swing arm is chrome plated so may also be non-stock? Other pictures show the solex carb mod, not sure if this was ever hooked up, and the oil cooler. So where these common modifications or something fabricated by the prior owner? Spot anything else odd? I am sure as I go through this bike other things will pop up. I think I have almost all the parts for the bike. From the condition of the fuel tank it looks like the prior owner was in the middle of shaving the emblems off the bike when the project stopped along with the carb install.Also this is my first Guzzi. Luckily included with the bike is a pile of shop manuals so I have some guidance to follow. Where are the good parts sources for these older Guzzi's?Thanks for the help.
That might be a modified BUB sump.information here - https://wildguzzi.com/forum/index.php?topic=93470.0
Just looked at the frame and engine numbers. Frame matches the pink but the engine does not. Engine serial is VG206927. What is that engine from? A web search seems to point to a SP1000? Any idea what year and what differences would it have compared to the original engine?
The floating rear brake caliper is a common modification. The force gets routed through the frame rather than through the swingarm and improves rear suspension performance. Common on race bikes.
Oh, interesting! I get the floating caliper part but was unaware of expressing that force up to the frame. Zero track time here,Art
SP 1000 engine numbers were VG 18781 - VG 25693According to Greg Bender's site, CX 100 began with "VU 111383 - ........"On your frame and title, do you have "VU" after "ZGU" ??
Not sure if that version is quite right as the LM 2 engine is exactly the same as the LM 1 which was homologated. So it would have been importable as an 850 cc just like the Euro bikes. But the US market wanted a 1000cc machine and to satiate that they simply put the G5/SP lump into a LM2 frame and called it the CX.
...the 850 was replaced by a one-liter version, called the Le Mans CX100. A couple of reasons prompted the displacement increase... For starters, the EPA was writing ever-tighter rules for motorcycle exhaust emissions. (This) would make the 850 too slow..... Second, the...US importer found themselves faced with ushering...three engines through the EPA tests. The V50...the 850s and 1000s...the Le Mans was booted upstairs to enjoy life with new 475cc cylinders. This year's LM shares with the 1979 edition all but its 80 mph speedometer... 1980s LM shares the same powerplant as the 1000SP: both engines have 948.8cc...compressi on ratio is 9.2;1, significantly lower than the 10.2:1 ratio used in the 850 Le Mans...(CX100) drag-strip showing: 13.50 s @ 98.46 mph...the old 850 Le Mans: 13.08 s @ 103.21 mph...(The CX100) got between 35.1 and 51.1 mpg, 41.9 mpg average
The frame and title are assigned VU 111449, original engine was T51461 according to the title.
T51461 sounds like the transmission number to me.
...Check those wheels. ...
I meant for you to check the wheels for cracks / damage. Not everyone will agree with me, but I wouldn't hang them on the wall just yet.Back in the day there were cases of magnesium wheels failing on new bikes. The debate was Fatigue vs. Road conditions vs. abuse vs. build quality. Not all magnesium wheels are created equally. I'd try contacting EPM first. See what they were using, and see what they recommend. I'd perform my due diligence and if I decided to run them, keep a close eye on them for damage. If you plan on riding through pothole city or Australia, then by all means swap back to the stock rims.my 2 centshttp://www.magni.it/epm_6_razze.htm
I'm not familiar with those rear sets. They look the business. I'm not sure what intake pieces those are? for the Solex?
I don't know if it has ever been done on a motorcycle but different length manifolds can affect torque. For many, many years I thought the intake manifolds on the Chrysler Slant Sixes were a design merely to save costs. Not so as I found out not so long ago. The unequal length runners were designed to provide maximum torque at low rpm, long ones, and maximum horsepower at higher rpm, short ones, with a balance in the middle. I doubt a motorcycle manufacturer would bother doing something like this. though.kk
Single carb manifolds for Guzzi’s have differences between left and right runners that I don’t understand. If you look at a single manifold from Sonny Angel the difference between the runners is obvious. The diameter and length are not symmetrical but I don’t remember what is the reason exactly, I expect part of it is the direction of airflow in combination with the degrees of rotation between power pulses. I won a Sonny Angel single carb setup complete with Mikuni carb at Ken’s Italy, TX rally . I never used it and donated to the Oklahoma rally . It ended up at Atlas Cycle, OK and don’t know if it was ever installed . I was told they were great for torque
The Scientific Design and Tuning of Intake and Exhaust Systems goes through that in detail with most of the testing done on a single 500 cc cylinder. Get a copy if it’s still in print - you won’t regret it
