Author Topic: Inquiry About Replacing the Ignition Switch on the 2017 1400 Model  (Read 1257 times)
Offline cuthbertdavies
If you haven't experienced issues with the faulty ignition switch on the 1400 (mine is a 2017), I commend you. This will be my second replacement. The first time, the dealer replaced only the bottom portion so I could retain my original key set. My question is this: Is it preferable to replace the entire unit, or does it make a difference? If I only replace the bottom portion, will it increase the likelihood of future failures? And if I opt for a complete replacement, what steps do I need to take to synchronize the new key with the ECU?
Offline pauldaytona
    • Paul's fast Guzzi Page
Re: Inquiry About Replacing the Ignition Switch on the 2017 1400 Model
« Reply #1 on: February 22, 2024, 06:59:19 AM »
When only the antenna(bottom) part is broken, there nothing to gain with replacing the rest. Question is, why did it brake second time? Cable damaged? The top and bottom part don't know each other.
Paul
Daytona 1225, Stelvio 1151
