Author Topic: Will this fit 200o jackal?  (Read 1915 times)
Offline Moda253
« on: March 05, 2024, 11:14:40 AM »
I know someone once told me that any to ti stand will work. But curious if this will fit. My bike does have some of the mounting pieces for a center stand so I wonder if it used to have one.
https://www.ebay.com/itm/115886777458?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=0lpFVkHQTf6&sssrc=4429486&ssuid=WrexnQ0AR1W&var=&widget_ver=artemis&media=COPY
2000 California Jackal (Currently under restoration)
Online Matteo
Re: Will this fit 200o jackal?
« Reply #1 on: March 05, 2024, 11:51:41 AM »
Should fit, I believe the frames are the same. It looks like the stand my Jackal came with.
« Reply #2 on: March 05, 2024, 12:03:27 PM »
I'll echo the "should" fit.
IIRC (and this was a while ago but I'm probably close on the details), when I first bought my Jackal in ~2003, the dealer also sold me an accessory used centerstand from "another Tonti model". It did indeed fit, though it might have been a little short as it couldn't fully lift the tires off the ground when deployed and IIRC it was narrow too and the feet were uncomfortably close to the rear tire enough for me to grind away a little assurance on each of them.
That said, I'm pretty sure it was off an older Tonti and a 98 and 00 would have been much more closely related so you're probably fine.
Offline Kent in Upstate NY
« Reply #3 on: March 05, 2024, 12:34:58 PM »
After grinding the stock centerstand in half on the asphalt I ordered the same centerstand of e bay and it fit just fine on my 2001 Cal Special.
Offline Moda253
« Reply #4 on: March 05, 2024, 02:51:19 PM »
Thanks guys! I think I will end up ordering it. Will let you know how ot pans out.
Offline Joliet Jim
  • Justus Esto, Et Non Metue
« Reply #5 on: March 05, 2024, 04:33:51 PM »
Should be the right one, looks like the one on my 01 Stone. Beware though, cheap metal which cracked at a weld and needed to be reinforced with better welds. It's been fine since.
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Just memories
The Psycho Chicken
The Fire Demon
Thumper
