Author Topic: V50 III refresh project  (Read 119694 times)
Offline jamesfjamesf
« on: March 06, 2024, 08:20:04 AM »
Hi all...new guy here...I picked up a 1981 V50 III which has has 3 previous owners since new, all of whom I know, so even though they are all of the age where memory isn't their most remarkable quality, I have an idea of it's history  :laugh:
It's mostly stock except for an electronic ignition, but sat unused for years until the previous owner bought it, and he and his son got it going well enough to just ride it, so I know all the major bits are fine, it just needs a lot of the perishables replaced. My main project focus is a custom paint job in V7 Sport red & green.  The frame is at the powdercoaters now and I just handed off the tank, sidecovers, and fenders to the local votech school for painting (for the cost of the paint!). Given the free labor I gave them the dented spare tank instead of the original brown tank which is in such good condition I'll keep it in case I come across someone who needs a brown one.
I've been toning my biceps reading Guzziology and will be following his recommendations on what mods to do and what to leave alone, mostly. I have absolutely no patience and tore into this the second it showed up, so a few things could have been done with less aggravation but this is not a new methodology for me  :laugh:
Has anyone here done a V50 rebuild? I don't see many mentions either here or out on the net in general. Most are big twins. Where do we get OEM/NOS parts? I've tried MG Cycle and Guzzibits but they don't have what I need - a taillight lens gasket, swingarm spacer (MIA). And of course tires are NLA in the stock sizes which I can't get a consistent info on- it seems most say 90/90 and 100/90 once converted to metric, but I read the latter is too big to get past the rear drive without airing it down. I'd love to hear some real life experience with these sized on the small twins. I can get scooter tires in the next size down which doesn't see too inappropriate  :grin:
More pics as the bits come in and get rejoined. Most now are for "where the hell did this go?" recordkeeping.
jim
Offline Tkelly
Re: V50 III refresh project
« Reply #1 on: March 06, 2024, 08:43:47 AM »
New paint is a great move,I thought the brown T3 I had was the ugliest Guzzi color but yours takes the prize.You will have a fun bike when finished.
« Reply #2 on: March 06, 2024, 09:47:36 AM »
I like the brown, always have since I saw the V50 III in that color new at my local dealer back in the day.
Parts for the early small-blocks aren't as easy to find as parts for the big-blocks of the same period. Harper's may have some hard-to-find bits. Here's the swingarm "spacer": https://harpermoto.com/products/washer-35214300 . The gasket for the taillight lens can be 3D printed. https://www.thingiverse.com/thing:5608853 You might also want an oil filler plug/dipstick wrench: https://www.thingiverse.com/thing:3992120
I used 90/90 and 100/90 tires on mine. It seems that no matter what size rear you use, it will need to be aired down to squeeze in.
« Reply #3 on: March 06, 2024, 01:09:51 PM »
Thanks! I'd forgotten about Harper's. Serendipitously, the friend I bought the bike from used the $$ to buy a 3d printer  :grin:
Several local friends have said they also like the brown, but the 70s V7 livery is something I've wanted to do for years. With the rear fender needing repair from the turn signal stalk cracking issue, and the stock brown side covers unusable, it's a reasonable candidate.
How does a hard plastic surface seal? I.e. how is it different from not using a gasket at all?
thanks,
jim
Online faffi
« Reply #4 on: March 06, 2024, 01:15:22 PM »
Congrats on your project - looking forward to follow the renovation :boozing:
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
« Reply #5 on: March 06, 2024, 03:32:38 PM »
I've never tried the 3D printed one myself, I just assumed that it's printed in a more pliable plastic. The original didn't do the greatest job after a few years, so I just leave it out. One could be cut out of thin rubber, foam or even gasket material.
« Reply #6 on: March 10, 2024, 02:51:52 PM »
I'm on the fence regarding painting the swingarm and wheels or just leaving them aluminum colored after blasting off the light blue color. Has anyone stripped the cast aluminum wheels and just left them uncoated? How bad do they get? Is Alumaclear a decent low effort coating?
thanks,
jim
Online Pescatore
« Reply #7 on: March 12, 2024, 06:52:36 PM »
I had the swingarm on my V65 blasted and powder coated.
The hardest decision was what color paint to pick.
The swingarm gets hit with road dirt and the powder coating is holding up well.
The shop I used didn't cover all the holes well enough, so I had to chase the pivot pin threads with a tap.
I would use paint stripper instead of blasting.
I've been thinking about doing the rims as well, but a good cleaning and buffing will do it for me.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #8 on: March 16, 2024, 06:26:15 PM »
The parts are back from the powder coater. I shoud have gone with my first color instinct of a darker red, but this color matched the V7 Sport pictures I saw, and it's called "Tomato Red", so....
Got the steering head assembled with new bearings into the old races, which I swapped top for bottom. Feels fine, no notches.
The ujoint had some play so I had to order one. If I were smarter I'd have checked it when I disassembled it rather than tonight during reassembly. I found one at http://www.theujointstore.com, hopefully it shows up in reasonable time. Weather was nice here for a few days so I'm getting impatient even though the body parts are probably 3 weeks out.
Someone added extra washers to the rear drive to swingarm connection. I looked on Schnoor's website and the smaller ones (13mm o.d.) are spec'd for M8 bolts. No idea why the 15mm ones were also on there. Has anyone seen this?
jim
« Reply #9 on: March 16, 2024, 10:00:18 PM »
The flat washers are so that the schnorr washers don't embed themselves into the soft alloy swingarm.
« Reply #10 on: March 16, 2024, 10:25:50 PM »
That sounds reasonable, except the bigger washers are also Schnoors, and they aren't on the fiche at Harper's. Is it something that was discovered by users afterwards? Should I replace them with flats?
jim
Online SIR REAL ED
  • uh.... it's personal....
« Reply #11 on: March 17, 2024, 08:46:48 AM »
I like that color, especially with the color of the stripes.  Very unique, very European.
2019 Beta EVO 250
« Reply #12 on: March 17, 2024, 12:24:18 PM »
jim
Unless they're serrated on both sides, they aren't schnorr washers. The ones that I've found on small-blocks are just fairly soft flat washers that the schnorr washers have left an imprint on.
One thing I learned early in Guzzi ownership is that the manuals don't always agree with how the bikes were actually built.
Online faffi
« Reply #13 on: March 17, 2024, 04:39:16 PM »
I think I have read somewhere that there is a tractor or Fiat u-joint that is cheaper than stock, but also much stronger?
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
« Reply #14 on: March 20, 2024, 08:57:23 PM »
Aha! Thanks! All 4 happened to land "imprint up" on the workbench so I assumed....  :rolleyes: I assembled it tonight (replacing that aluminum one) and added a bit of loctite for good measure. The manual doesn't list a torque spec so I used 28.8, the generic M* spec.
jim
« Reply #15 on: March 20, 2024, 09:06:56 PM »
It probably would have grown on me, but I'm pretty sure I'll like the new color scheme much better. I've seen R bikes in that brown and I think they're much more suited to it.
jim
Online SIR REAL ED
« Reply #16 on: March 21, 2024, 08:08:48 AM »
jim
Yeah, sometimes pictures can hide ugliness or beauty.  Nothing like seeing the bike in person.
To my eye, that color was something between a brown and an olive green.
In any case, you will have a cool, unique bike, that is personalized.
That is never a bad thing!!   :grin:
2019 Beta EVO 250
« Reply #17 on: March 21, 2024, 08:45:01 AM »
I nearly bought one when they were new. They were "root beer brown", no olive tint or anything else. My white V50 III was repainted from that color.
Online SIR REAL ED
« Reply #18 on: March 21, 2024, 09:31:45 AM »
Thanks.  That what I originally thought.  The picture is misleading to my eye.
That bike looks good in white with a red & green stripe also.  White is very under rated as a motorcycle color IMO.
The only other bike I know of that used "root beer brown" as a color with the first Kawasaki Z1's.
2019 Beta EVO 250
« Reply #19 on: April 01, 2024, 01:27:38 PM »
Contrary to my usual M.O. I've been slowly putting the bike back together as I get time here and there. I failed to adequately document the wiring harness routing so that has taken quite a bit of time to get in place, and I'm only about 60% done. I'm waiting for the bodywork to get finished at the painter's before I can install the rear mudguard which holds the toolkit which holds the diode board. Rims are (still!) at the powdercoaters but tires have arrived. And the exhaust needs replacing but I haven't decided which one yet. Likely Keihan, they seem to have the best reputation over the years. We've had a few nice days already here in the northeast USA so I'm getting antsy.  :laugh:
jim
Online faffi
« Reply #20 on: April 01, 2024, 02:04:12 PM »
No fan of wiring. I began by mixing parts of the old harness with most of the newer harness when I built a Virago consisting of part Gen 1 and part Gen 2. Last year, I simplified it and made a full new loom. Time consuming, frustrating - and satisfying when all work the first time you turn on the ignition :boozing:
Sorry for the hijack - please let me know if you want me to delete!
Starting off
On my way - hard to believe I had by then eliminated a lot of relays and wires
Finished
« Last Edit: April 01, 2024, 02:05:07 PM by faffi »
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Online SIR REAL ED
« Reply #21 on: April 03, 2024, 06:48:22 AM »
that wiring simplification looks like it was well worth the effort.
2019 Beta EVO 250
« Reply #22 on: April 10, 2024, 09:50:37 AM »
I got most of the body parts back this morning (tank needed a clearcoat touchup which they're doing today) and it looks fantastic. This is the '96 Nissan Micra "Yellow Olive" (code ER4), but I think the current Kia or Ford version would have worked just as well. Also had the rims blasted and matte clearcoated and they really match the frame's red nicely.
Now I just need to get over my mental hump of paying $700 for a new nice exhaust....I'll see how the black looks but I know I'll like the Keihans 1000 times better.
jim
« Last Edit: April 12, 2024, 06:02:17 AM by jamesfjamesf »
Online faffi
« Reply #23 on: April 10, 2024, 10:35:47 AM »
Coming along really nicely :thumb:
Current bikes:
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Online Pescatore
« Reply #24 on: April 10, 2024, 08:38:16 PM »
Striking color. Almost like the V7 special.
What did you end up doing to the wheels?  They look like new.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #25 on: April 11, 2024, 08:54:35 AM »
The V7 coloring was my inspiration. Once I get it all together I'll look into editing an original decal into "V5 Sport" :-)
The rims I just had them blasted and matte clearcoated. I was skeptical since I didn't know what the aluminum would look like underneath the paint, or if it would discolor, but I'm super happy with how they came out, especially with how well they match the red.
jim
Online Pescatore
« Reply #26 on: April 11, 2024, 08:17:41 PM »
Please tell me you plan to take the engine back out to clean it...
Do you also have the Dyna pickup or the old points?
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #27 on: April 12, 2024, 06:00:38 AM »
Dyna pickup.
I tried about 655 different chemicals on the engine and each one did a little bit but the aluminum kept turning the same dark color so I gave up. I briefly investigated vapor blasting it as a unit, and a friend in the business told me there was no way to keep the grit out of the openings. I absolutely did not want to disassemble a working engine just for aesthetics. Maybe next winter I'll look into making a smaller, lower pressure vapor blaster, or maybe soda blast it in someone's back 40. But cleaning an engine, man once you start you have to do it all, every part, or else it looks like you got lazy (which I am  :grin:).
jim
Online Pescatore
« Reply #28 on: April 13, 2024, 11:50:39 PM »
I realize now they are stains, not dirt.
My engine was painted and oil had penetrated and stained the aluminum.
The only way I could get them off was bead blasting.
With Gorilla tape and not shooting directly at the covered openings, nothing got inside the engine.
It is a messy job and I wouldn't try it again.
https://wildguzzi.com/forum/index.php?topic=102352.msg1701449#msg1701449
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #29 on: April 14, 2024, 09:11:20 PM »
I spent the past 3-4 days trying to get the rear fender mounted so that it would be isolated from the frame and there would be no torque on it from the triangular shape of the fender wall. In addition to fabricating sleeves with grommets and drilling out the fender holes, I had to bend the bender mounting brackets back into position so they matched the inside angle of the fender wall.
If I knew it would take this long I'd have ordered the grommet and sleeve form Harper's for $25 and waited the week for shipping. I'm satisfied with the end result but not proud of the hack. Also not impressed with what was clearly a hack from Guzzi getting the fender mounted. But I had about a CC of Simichrome left to polish up the grab bar and the 70s vibe makes me smile.
jim
direct english film
