Author Topic: Check your connectors.  (Read 2160 times)
Offline hzbloke
« on: March 08, 2024, 07:28:39 PM »
2008 Breva 750.
It's the connector between the alternator and the regulator. The problem has been talked about on this forum several times and Brad The Bike Boy has a good page on it here: https://www.bikeboy.org/chargingsystemdiagnostic.html
I didn't read any of these until after I had broken down.
The spade connectors and some of the wire corrodes and stops conducting electricity. I had no apparent problems or early warning signs. The bike started and ran beautifully for a 30km ride. When I went to start it again the battery was clearly flat. It showed about 10v but the bike started easily with a jump start. A smarter person would have noticed that the volts didn't go up when the bike was revved. I got about 5km before it stopped again.
2019 Kawasaki Z900rs
2008 Breva 750
1986 BMW R65
Offline normzone
Re: Check your connectors.
« Reply #1 on: March 08, 2024, 08:35:09 PM »
(insert expletive of your choosing here)!
I saw that top image and I thought that sea urchin roe had got into the bike ...
« Reply #2 on: March 09, 2024, 06:47:22 AM »
I've sang the praises of Caig DeOxit for years. And years. It falls on deaf ears, mostly, but I can't begin to number the things I've fixed with it. Expensive, and worth every penny.
Offline sign216
« Reply #3 on: March 09, 2024, 06:50:47 AM »
I had that on my '09 V7.  Fortunately I have a voltage gauge, and that gave me an early warning.  The bad connector is in the harness along the main frame, directly under the fuel tank.  The factory put out a notice about the problem connector, but their "fix" is to zip tie the connector tight, to stop arcing of the loose connection.  Not sufficient.  I ended up soldering the joint.
Joe
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #4 on: March 09, 2024, 08:20:10 AM »
Where is that LIKE button.
Some people would smear insulating dielectric grease on that and think they helped it.  :rolleyes:
« Reply #5 on: March 09, 2024, 08:34:13 AM »
I heard 'ya Chuck. I wish I'd known about that stuff when I was into power mobility equipment.
« Reply #6 on: March 09, 2024, 02:35:17 PM »
One of Dorcia's friends husband had a dead mobility scooter. Couldn't find *anyone* to work on it. Squirted the ignition switch, and it came to life and gave an error code for the reversing switch. Squirted that, and it's been running ever since.  :smiley: Got a filet dinner out of that one..but fixing my Mondo expensive TIG welder was the last big one.
« Reply #7 on: March 09, 2024, 06:41:46 PM »
A customer's crusty Jackal will likely use the whole can.
