Hi, I've just fitted a Dominator (Made in Poland) decat pipe & muffler to my '20 V85TT Travel. I was after a bit nicer sound & the maintenance advantages of the decat. It came with a Decibel Killer installed. Well, the sound was fine... but I seemed to lose a fair bit of low to mid torque & throttle response. It also cackled & backfired like crazy on gear changes and over-run. So, I removed the Db Killer and now I have everything back (and more I think) as well as a deeper sound. Yes, it is fairly loud but nothing like half the Harleys getting around here. Cold start idle is a bit fluctuating, but it soon idles normally. It doesn't backfire as much as before with the Db Killer in. In fact, I'd say it doesn't backfire any more than before the new exhaust... you can just hear it more & it can be mitigated by adjusting my throttle technique. I'm very happy with how the bike is running, however I posted about this on a few F/book pages and got a few comments advising I should not have done this without a remap or fitting plug in foolery... lean running etc etc..My question is...do I need a remap...is it imperative? I've studied Griso.org's instructions re- installing a new map and it seems pretty straight forward. I've also ordered the required leads to use Guzzidiag.Can anyone offer advice on what I should be doing? Again, the bike is running great now, but I don't want to cause damage to it and if a new map liberates it a bit more than that would be good too.regards,Mick
Hi Mick,I have just joined the Wildguzzi forum and and saw your post re the Dominator exhaust. Hope you do not mind if I ask some questions about it as I been thinking of getting one for my V85TT 2022, at least the muffler as they don't seem to have the exhaust pipes for the Euro 5 model. Are you still happy with it ?Is the material and fit quality OK ?Did you need to disconnect the lambda sensors ?Another question, can you run your bike on 95 RON or E10 ? Mine must run on 98 RON otherwise it pings too easily when the ambient temperature is above 28 degrees Celsius or so. The idle is fluctuating, not only when cold.I should probably also get an aftermarket remap to try to get rid of the pinging.Cheers,Larry
