Author Topic: Norge Brake wiring connection  (Read 1107 times)
Online SemperVee
  • USMC Retired
« on: April 28, 2024, 12:58:15 PM »
 I believe I am holding the rear brake connection in my hand and was thinking of splicing into one of these wires for my LED AUX Hyper-lite add.  Can anyone share what wire I should spline into or more than one wire??
53 years of Street Riding - All Brands
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
Paul_Tim
Re: Norge Brake wiring connection
« Reply #1 on: April 29, 2024, 04:33:53 AM »
If it's the same as the Stelvio Blue is Ground, Yellow/Green is switched 12V from the brake switches and Yellow/Grey is 12V for the tail light. Quick check with a meter / bulb should confirm it.
Online SemperVee
  • USMC Retired
« Reply #2 on: April 29, 2024, 10:19:19 AM »
 Thanks Paul.   I think I also need to install a diode or two? - to get it to flash? Do I use one or two diodes as there are two lines separate from ground. *Positaps thanks! Here is what it looks like attached now. Lighting up but not flashing as it should. I believe I need to add a Diode, but to which or both wires is my understanding?
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Paul_Tim
« Reply #3 on: April 30, 2024, 09:06:04 AM »
Can't help you on the diodes as I don't know the lights/system in question.
Hopefully an adult will be along soon to help you out.
Online Pescatore
« Reply #4 on: May 01, 2024, 08:16:11 AM »
I would try their troubleshooting chart.
https://hyperlites.com/support/
The module should do the flashing without any external parts.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Online SemperVee
  • USMC Retired
« Reply #5 on: May 01, 2024, 09:51:16 AM »
Thanks for bringing that up, It's a great idea & I have done that>>  Also sent email questions to the company.  Thus far no response from Hyperlites..
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
Online SemperVee
  • USMC Retired
« Reply #6 on: May 06, 2024, 05:08:49 PM »
UPDATE*  Once I installed a Diode and redid the permanant  wire connections with Posi Taps all is working as it should!    Gotta love a happy ending.
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
