Author Topic: fuel sender/sensor for 1998 EV?  (Read 6854 times)
Online John A
Re: fuel sender/sensor for 1998 EV?
« Reply #30 on: May 07, 2024, 10:46:17 PM »
I can't get a replacement for the low fuel light sensor either.  I just use the trip odometer.  I fill at 140 miles or so.  Those things have been out of stock for a long time.
This is another example of why technology might not be desirable, the subject of another recent post.
« Reply #31 on: May 08, 2024, 02:44:34 AM »
But it is low tech. It is a 'rock' with two wires attached. It is not that hard to solder a new one inside the can.
Online John A
« Reply #32 on: May 08, 2024, 10:13:26 AM »
Too bad its not as reliable as the proverbial rock.
« Reply #33 on: May 09, 2024, 10:10:06 AM »
It generally speaking is very reliable. But some engineer decided to use an identical 12 volt connector beside it. Get them crossed, and it can melt the solder off of the rock.
Online John A
« Reply #34 on: May 09, 2024, 11:19:05 AM »
Yeah, you can’t blame the component for a human factors failure.
A sharp lawyer could  :grin:
Offline AZRider
« Reply #35 on: May 17, 2024, 01:02:39 AM »
I’m glad Wayne already said this, I am just repeating so it doesn’t get missed.
You do NOT want a petcock with a reserve function. Fine for carb bikes where fuel starvation just makes the motor stumble and you turn on reserve before it stalls. Not OK for injected bikes. First of all, the fuel pump will burn itself up without fuel flowing through it. Secondly, even if the pump wasn’t designed that way, injectors either have enough pressure to work or they don’t. So the engine would just die without enough warning to switch to reserve.
Another option that nobody has mentioned is to switch to get a later model fuel tank with the pump inside. Bigger project, but doable.
Trying out the motorcycle life from the other side of the counter.
