Author Topic: electrical connections  (Read 1595 times)
Online SIR REAL ED
  • uh.... it's personal....
« on: May 06, 2024, 07:23:51 PM »
https://www.amazon.com/dp/B0B1PSLWWF?psc=1&ref=ppx_yo2ov_dt_b_product_details
Has anyone used the solder connectors that have the solder contained inside the clear shrink wrap?
Did you like them or not?
thanks in advance!
2019 Beta EVO 250
Online BMCMOTO
Re: electrical connections
« Reply #1 on: May 06, 2024, 07:35:09 PM »
I have tried them and was not satisfied. The heat required to melt the solder was too much for the heat shrink. The ones I tried were single wall heat shrink, which I am predisposed to dislike because, when I use heat shrink, it is normally to seal a connection. I really wanted to use them because they were clear and any corrosion would then be obvious on visual inspection. The version I tried was available in the early 90s, maybe they've come some distance since then. The ones I tried were supplied by an industrial electrical supply house. Great idea but not quite right for me.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline 1down5up
« Reply #2 on: May 06, 2024, 07:52:40 PM »
I have used them quite a bit and found them perfectly adequate - key is to ensure you use the right size so there is good contact on the solder ring, i usually give them a sueese with my finders so they make nice contact - and use a small butane torch to heat them up.
when done well they are quite strong.
Offline pehayes
« Reply #3 on: May 06, 2024, 10:57:40 PM »
I thought they were brilliant.  Used in several applications.  Everything seemed to melt and flow as expected.  They have low temp solder, a weatherproof sealant, and shrink tubing all in one.  Kit off of Amazon.
Offline faffi
« Reply #4 on: May 07, 2024, 01:10:22 AM »
My soldering skills are not up to these, so I quickly concluded I would stay with the old fashioned way of soldering first, then pull over the heat shrink and, well, shrink it in place. Also, I worry if the connection is strong enough, or if the wire ends are mostly held in place by the shrink wrapping.
Current bikes:
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Offline paulbricey
« Reply #5 on: May 07, 2024, 04:47:00 AM »
Agree with faffi....doing it 'old fashioned way' means you can pre-flux the wires, join & check, easily undo & redo if required & you can 'tell' the wire is strong (can also pre-twist/hook/etc together the wire ends if you aren't worried about space). Pic is from V50 restoration with Domino (chinese versions) switchgear spiced into OEM loom.
Riding to live
Offline ital4me
« Reply #6 on: May 07, 2024, 07:16:50 AM »
Nice work Paul. Very clean and tidy.
Offline Zenermaniac
« Reply #7 on: May 07, 2024, 08:04:44 AM »
As a retired electronics engineer I prefer the old fashioned way. I know my work.
