Author Topic: Why do they still do that?  (Read 2827 times)
Offline faffi
« on: May 07, 2024, 02:02:39 AM »
There is one thing that I never stop wondering about. Or getting annoyed about. And that is mismatched suspension between front and rear on motorcycles, where one end is soft and the other firm. Quite often with damping rates that do not match the springs. Yet this is more the norm than the exception. One must wonder why the bikes are sold like this, because I cannot for the life of me imagine their test crews would think this is a great setup.
No need to read any further unless you too is a nerd :grin:
I can use my 2017 V9 Roamer as an example. 6000 miles on the clock, so parts are not worn out. Over sharp bumps, like frost heaves, they both feel harsh, although for different reasons. But for the most part, when one end is OK, the other feels harsh.
The reason is that the shock absorbers have too soft springs and soft damping, whereas the front have the correct spring rate for a 200-220 lb rider, and they will allow fairly sporty riding, with damping set for control rather than comfort. But unlike most budget suspensions, spring rates and damping rates are reasonable.
The shocks are OK for a light rider riding solo, but too soft for a 200-220 lb rider. So they bottom out frequently over larger bumps, but do a reasonable job over smoother roads. One can up the preload, but that would not change that the spring rates are too soft. And the damping cannot control stiffer springs, and also adding more preload will ask more from the rebound than it can deliver. Still, as an economy alternative, I think they are acceptably matched, spring rate to damping, but too soft. IMO, any rear suspension must be able to carry the maximum allowed weight for the bike in reasonable control and comfort.
The fork springs, as mentioned, are quite firm, and well up to the task of supporting a full load. The problem, for me, is the unsophisticated damping. There is too much compression damping, likely chosen to reduce the rate of dive under braking, that make the front wheel skip over sharp bumps instead of absorbing them. I can forgive this, because most people prefer this over suppleness and rapid diving under braking. There is also quite a lot of rebound damping, which make it impossible for the front wheel to drop quickly enough into bigger dips. Again, the setup overall is an OK compromise. Not for racing, but for sporty riding, or riding with a full load. More comfort can be had by simpl changing to a little thinner fork oil than stock.
However, the real issue I have is again that the front suspension and rear suspension do not work together! If both ends were soft, like the shocks are, I could understand that. Same if both ends were set up on the firm side. But not like this. It does not cost any extra to have spring rates that mirror each other functionally, nor does it cost anything extra to have damping rates that matches.
What do cost is sophisticated valving that will allow the suspension to work over any kind of terrain, and I fully understand that bikes built to a budget does not have this.
« Last Edit: May 07, 2024, 02:02:58 AM by faffi »
Current bikes:
2002 BT1100
2018 V9 Roamer
1982 XV750/1100 mongrel
1990 XT600Z
2001 NT650V in bits
Online cliffrod
Re: Why do they still do that?
« Reply #1 on: May 07, 2024, 06:07:48 AM »
It’s a function of mass and inertia.  The loads created/imparted by braking are generally higher and more consistent on the front forks than the loads imparted by normal vertical loads imparted upon the rest suspension.
When the surface is irregular and braking is required, the front suspension must compensate for both factors at the same time.
By contrast, the rear suspension normally unloads during braking. This helps supplement the action of the softer rear suspension.
The factory “mismatch” is done as a means to address the needs of the average consumer within a given price point.  That consumer can then modify suspension to better match their actual weight, style and amount of use.  Even if manufacturers produced perfect suspension, they would have no way to know these specifics to employ them on a production scale.
Offline Zenermaniac
« Reply #2 on: May 07, 2024, 08:36:32 AM »
On my Roamer I changed to 5W (17.5cst @ 40c) fork oil as opposed to the factory fill Agip which is 7.5W (32cst @ 40c) and an air gap of 130mm instead of 120mm. The negative of this is a little more fork dive but I was after a little more plushness on ordinary road surfaces. Mission accomplished.  In my old age I’m a more sedate rider and no longer need sophisticated performance for canyon carving.
« Reply #3 on: May 08, 2024, 08:12:30 AM »
This is the answer ^
All motorcycles are built to a price point.  They're also built to an "average rider".
Even a $5,000 Ohlins setup won't work for a 250 lbs rider, if it's tuned for a 160 lbs rider.
When I got my V11 Nero Corsa years ago, with its nice Ohlins suspension, I had to soften the compression and rebound on the front fork and replace the factory rear spring with a stiffer Ohlins replacement.
« Reply #4 on: May 08, 2024, 08:14:23 AM »
On my Sport 1100 Carb, I had to do the opposite.  Changed out the spring and went up to 10wt oil in order to firm it up a bit.
Offline faffi
« Reply #5 on: May 08, 2024, 04:31:37 PM »
My point is that you should have a similar amount of sag front and rear, unladen and with a standard sized rider on the bike. Way too often, bikes fail miserably, with one and leaving the factory with too soft and/or too firm springs at one end. If both ends were too soft, or too firm, one could argue the bike was set up for a different weight rider.
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
Offline Bulldog9
« Reply #6 on: May 09, 2024, 12:54:47 PM »
That's the way it's always been especially on a non-adjustable suspension. As others have said multiple times it's a reality when you buy a motorcycle that you will be adjusting sag (front and most importantly rear)  rebound, compression etc to your weight, style of riding, and road conditions.
And let's be real, motorcycle manufacturers KNOW that one of the first things serious riders will do is modify their suspension to suit their needs so very few put top dollar big money into their suspensions.
Even amongst riders of similar size and weight, some find the stock suspension and setup completely adequate while others hate it. Some people are very particular about their suspensions and some aren't.
Of the 15 to 20 motorcycles I've purchased over the years, the only one I found that absolutely required suspension work was my v7ii Stornello. And even as bad as that stock suspension was, if I was only putting on it around town and had very smooth roads and didn't plan to load it down with bags and touring gear for all purpose/advstyle distance riding, it would have been adequate.
« Last Edit: May 09, 2024, 01:04:03 PM by Bulldog9 »
MGNOC#23231
Offline mechanicsavant
« Reply #7 on: May 10, 2024, 07:24:15 AM »
As the owner of 2 late model small blocks , yes suspension components are built to a price point as are the tires . Harshness on small road irregularity’s is primarily the tires . As many have posted here , switching to radial tires is one of the biggest improvements ya can make !
Offline faffi
« Reply #8 on: May 22, 2024, 02:22:32 AM »
Current bikes:
2002 BT1100
2018 V9 Roamer
1990 XT600Z
2001 NT650V in bits
