Author Topic: No spark- Cal II  (Read 2368 times)
Offline Petrus Rocks
No spark- Cal II
« on: May 09, 2024, 10:19:11 AM »
I installed a new battery in my '85 Cal II.  When I turned on the ignition the voltage regulator started smoking.  Put in a new regulator  wired as before.  Then I had no spark.  When I crank the starter there is no power to the coils. The Guzzi service manual has poor wiring schematics.   there is new wiring, unfortunately it is all black, very hard to trace.
Points ignition updated Enduralast alternator and voltage regulator
What I want to know is how the starting circuit is wired from the ignition switch to the points and coils.
Where should the coils get their power from?
thanks, Pete
Re: No spark- Cal II
« Reply #1 on: May 09, 2024, 11:04:04 AM »
Coils get power from ignition switch, wire goes to kill switch then to coils.
I have a Cal2 also, installed a new loom, the whole thing like factory. My fuse box had 1/8" of solid blue cakey corrosion all over the back & it was replaced w/newish one.
« Reply #2 on: May 09, 2024, 11:57:35 AM »
Thanks Guzzisteve!  The wiring and fuse block are in very good shape.  I can install a new wire loom but don't want to yet.  I can run a hot wire from the ignition switch and bypass the kill switch.  The switch had tested as good.
« Reply #3 on: May 09, 2024, 12:20:57 PM »
15/54 terminal on ign switch is white wire, that goes to kill switch & coils. Points get wired to other side of coil for L & R.
« Last Edit: May 10, 2024, 08:27:42 AM by guzzisteve »
« Reply #4 on: May 09, 2024, 10:11:26 PM »
What caused the smoke to leak out of the regulator?
« Reply #5 on: May 10, 2024, 09:37:19 AM »
No more white wire to the kill switch.  I did test the kill switch seemed to work.  40 yr old switch may be shit.  I have no idea why the regulator started smoking.  One of the reasons i wanted to understand the ignition system was how the regulator is wired into it.
« Reply #6 on: May 10, 2024, 10:06:18 AM »
If you look in the 1000SP/G5 manual it explains the charge system, easier than trying to explain by typing. It has pics.
« Reply #7 on: May 12, 2024, 09:39:23 AM »
Changed the condensor, I now have no spark on one side.  Factory manual says coils are 3.5 ohms.  Also seeing spark from one set of points.  been so long sice I messed with points.  Will check points gap, coil resistance
« Reply #8 on: May 12, 2024, 10:04:37 AM »
The charging system is completely independent of the ignition system, the regulator should not be wired into the ignition in any way.
There are two condensers.
Offline centauro
« Reply #9 on: May 12, 2024, 03:27:48 PM »
Take a look at the 4-wire junction plug that connects the kill/start switches on the throttle side. You should have 4 wires plugging into that block, which should be somewhere near the right side of the steering neck: 1 black wire, 1 white/black wire, and 2 white wires. The black wire is the path to the ground, the white/black goes to the starter relay, and the 2 white wires are live 12V when the ignition switch is ON and the kill switch is OFF. As stated above, the white wire feeds the coils + terminals. If that one shorts to the ground, it means no spark.
On my SP, which shares the same diagram with the Cal II, that junction plug was corroded and melted. I had to cut it out and put new terminals on all 4 wires, plus I had to completely replace the white wire feeding the coils, since its insulation was melted 2 feet into the main harness under the tank.
Val Barone
1984 1000 SP/NT (sold)
1985 Vespa PX150E
1973 Honda CB 350 Four
« Reply #10 on: May 14, 2024, 01:56:50 PM »
I now have spark on both sides. Point gap is .017-.018.  New plugs, idles rough.  The left cylinder doesn't seem to be firing all the time.  Going to pull the jets, clean the carb.  Did the right side.  Also adjusted the valves.
I do not have that 4 wire plug anymore.  It has been replaced with new wiring and a relay.
 Charlie, two wires go to the alternator, one to ground and one to the battery, correct?  Enduralast/Ducati alternator
Thinking new coils are next...
« Reply #11 on: May 14, 2024, 03:53:15 PM »
From their website...
The one that is designated "starter" can also be connected to the + terminal of the battery. The one that is designated "coil" can be connected to any switched power supply.
« Reply #12 on: May 15, 2024, 04:05:15 PM »
I'll double check my wiring, thanks Charlie!  Replaced the other condensor, cleaned carb, no change, left cylinder is only firing with a lot of revs.  Ordering two coils next
« Reply #13 on: May 15, 2024, 07:03:04 PM »
Just checking if you cleaned the bottom of point plate and top edge of dizzy? Being clean & oil dry makes a difference.
« Reply #14 on: May 22, 2024, 10:56:50 AM »
Waiting on the coils.  Thanks Steve, I'll check .
« Reply #15 on: May 27, 2024, 12:17:42 PM »
  :violent1:  new coils wires and spark plug caps.  At low revs left cylinder not firing, higher revs will fire.  I guess order a set of points and check compression on left cylinder.  No oil/grease on points.
