Author Topic: V85TT key clone  (Read 2543 times)
Offline steven c
V85TT key clone
« on: May 13, 2024, 12:32:58 PM »
 When I bought my bike after signing the paperwork the PO told me had misplaced the spare key but he knew it was in his shop and he would get it to me of course that never happened. So last week I went down to the Guzzi Dealer got two Guzzi blanks had them cut at the local hardware store went back to have them programed and they could not do it because whoever the first owner was changed the security code and they could not program the key even after a few phone calls to see if there was a way. So today I went do a very good locksmith to see if they  copy the key but they couldn't, the two machines they had to clone did not see the Guzzi blank so he made up a key with a new chip and when we tried it the dash came alive but wanted the security code which I do not have. So I have two worthless keys which cost $57 dollars each and only one key. Yes I did ask the PO if he had the code and he knew nothing about it and he never got back to me on who he bought it from. So don't buy a V85TT with only one key W/O knowing the code. Lesson learned.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline azccj
Re: V85TT key clone
« Reply #1 on: May 13, 2024, 01:17:35 PM »
I know one of the Guzzi dealers I do business with, program’s the code to be the last digits of VIN number. If that won’t work, contact AF1 racing. They offer a service that can clone your one key so you will have 2 of them having the same internal code,  https://www.af1racing.com/AF1-KeyCloning-EXT-AF1-Racing-Key-Cloning-For-External-Cut-Keys  . Most likely if you send them the 2 newly cut keys you have, they would be able to program those keys so you wouldn't be wasting the $114 you already spent on those keys. If that won’t work then your only option is to buy an entire new lock set which will come with all the locks and two new keys,  https://www.af1racing.com/2B006828-BLOCK-KIT-TRAVEL-PACK  . Which the dealer should be able to program to the bike.
« Last Edit: May 13, 2024, 02:11:03 PM by azccj »
2023 V100 Mandello S
2007 Norge
2003 V11 Le Mans
2000 Jackel
99 EV
Offline steven c
Re: V85TT key clone
« Reply #2 on: May 13, 2024, 03:41:33 PM »
 They tried that both first 4 and last 4. And the locksmith did clone the key that worked but without being able to enter the proper code it will not connect.
2020 V85TT Traveler
74 949 Eldorado
75 Benelli 250
2006 Buell Ulysses
78 Honda XL125
MGNOC 6412
Offline Ed / AF1 Racing
Re: V85TT key clone
« Reply #3 on: May 13, 2024, 04:23:45 PM »
posting some answers from the emails
your locksmith did not clone it right if its asking for the code.  A clone does not dealer help.   A clone is an exact chip copy of a working key, the bike does not know the difference.  You could have a million clones, bike doesnt care.
Every OEM key has a fixed and random chip in it.   Bike needs programmed to accept it.  On the TFT dash models (V100, v85, new V4), that requires that dealer and the USER CODE.   On the non-TFT dash bikes with immos (Griso, Norge, early aprilia V4), you can add OEM keys in the dash menus using the USER CODE
Yes, clones are chip copies using special blanks and chips.  Ready to use.
We have to copy a working key.  Order this and send it in
We cannot do anything with your two new OEM keys.  Those chips cannot be changed, and they cannot be reprogrammed.  They are fixed and random chips inside.     The bike’s dash has to be programmed to accept them.    The USER code and a dealer computer is required for that.   The personal user code can only be reset with both original keys.
No harm in guessing the user codes….try one of your new OEM keys, and it will immediately ask for the code on dash screen.   Guess it right and the dash will boot up and bike will run.
Online ridingron
Re: V85TT key clone
« Reply #4 on: May 13, 2024, 08:27:14 PM »
Other than guesses such as year of birth, birth month & date (previous owner), year of bike, SSN number etc, guessing a 4 digit number probably has less a chance than getting hit by lightning.
But, what is there to lose? Go for it!
Offline Joliet Jim
  • Justus Esto, Et Non Metue
Re: V85TT key clone
« Reply #5 on: May 13, 2024, 09:46:08 PM »
Bikes are way too complicated these days. I miss the prime the carbs, turn the key, and stomp on the kickstarter days.
2002 Cali Stone "Moby Dick"
2003 Buell Blast "Pegasus"
Re: V85TT key clone
« Reply #6 on: May 14, 2024, 08:33:03 AM »
Where did the PO buy the bike?  Hopefully he purchased it new.  You could contact the dealer to see what their standard key code is.
Offline dave1068
Re: V85TT key clone
« Reply #7 on: May 14, 2024, 08:57:22 AM »
I thought the code was always 0000 unless changed
Dave
-2024 Moto Guzzi Stelvio
-2023 Moto Guzzi V7 Stone
Re: V85TT key clone
« Reply #8 on: May 14, 2024, 12:22:15 PM »
they are 00000 from MG, but can be changed to anything by the previous owner/dealer
Offline cappisj1
Re: V85TT key clone
« Reply #9 on: May 16, 2024, 08:45:41 AM »
10000 possible combos * 5 seconds per combination = 13.89 hours. 🙂.
73 Eldorado
75 T Cafe
08 Norge
23 V85 Travel
