Author Topic: Bent steering stem replacement  (Read 5586 times)
Offline texasmoto
« on: May 16, 2024, 10:06:40 AM »
A friend doing some vapor blasting noted that the steering stem was bent.
I looked for a part number but it doesn't look like Guzzi differentiated this part from the lower part of the yoke
Digging around on ebay I found this, but want to make sure that it is an appropriate replacement before ordering:
https://www.ebay.com/itm/202182148260?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=rbcbQrIITFy&sssrc=2047675&ssuid=&widget_ver=artemis&media=COPY
Online RinkRat II
  • Lake Powell AZ
Re: Bent steering stem replacement
« Reply #1 on: May 16, 2024, 02:35:32 PM »
   I'd put it in a set of v-blocks, with a dial indicator see how much it's out and put it in a press and GENTLY apply pressure 'til it's within a few thousands.  If you're not comfortable doing that, a decent machine shop can do it.  My $.02
   Paul B :boozing:
Offline texasmoto
« Reply #2 on: May 16, 2024, 03:11:27 PM »
I'd be open to that, if that kind of machine shop existed in Austin!
Offline n3303j
  • Ron Cichowski
« Reply #3 on: May 16, 2024, 04:04:00 PM »
Curious where and how it's bent.
Folded a fork on the Ural in a T-Bone.
Folded the fork on my T3 in a high side.
Both times the steering tube came out straight.
The fork tubes between the two clamps would have to bend for the steering tube to bend.
Three tubes bending is really rare considering that the unsupported section of the fork bends and absorbs the impact first.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online RinkRat II
  • Lake Powell AZ
« Reply #4 on: May 16, 2024, 04:44:30 PM »
   Sometimes you gotta get creative, an electric motor shop, pump repair shop and even a bicycle repair should be able to do it for a case of beer. I've seen parts houses with those capabilities (NAPA)
   Paul B :boozing:
Offline texasmoto
« Reply #5 on: May 16, 2024, 05:00:02 PM »
Well, there is also this unusual dent on the front fender.
The damage is odd. And I bought the bike in complete condition. It hadn't been crashed.
But, I wasn't the one to remove the steering stem. Apparently the lower bearing can really get stuck? Who knows.
Offline n3303j
  • Ron Cichowski
« Reply #6 on: May 16, 2024, 05:36:57 PM »
Had that same dent on my T3 front fender after the "high side". Bent both fork tubes and the rim.
Don't have to pull the stem to remove lower bearing race as long as you are willing to bend the lower dust shield. A Carpenders wood chisel tapped into the junction between the lower clamp and the dust shield will act as a wedge and lift the inner race enough to get a puller in place.
« Last Edit: May 16, 2024, 05:38:18 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline moto-uno
« Reply #7 on: May 16, 2024, 05:48:04 PM »
  If you're from Austin , Texas , you have an excellent machine shop , owned by a Joe Pie ( his shortened YouTube channel name ) , check him out . Peter
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #8 on: May 16, 2024, 06:58:50 PM »
RinkRat II is correct. Piece of cake repair.
I would be amazed if a machine shop existed that could not do that type of repair.  I would not expect them to stay in business for more than a week.
« Last Edit: May 16, 2024, 07:00:21 PM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline Mike Tashjian
« Reply #9 on: May 17, 2024, 06:51:37 AM »
I have a ten ton press in the garage I made years ago.  Funny that I just used it yesterday to press in some bushings and ball joints on a old Mopar my friend owns.  I also straightened a bar that goes to the lower control arm.  Almost too easy.  Seems the shop working on the car has no torches or press. I bet they could program the computer though, wait that 60's Chrysler doesn't have one.
Online John A
« Reply #10 on: May 17, 2024, 10:04:46 AM »
Check the yokes for being flat with the stem out. Check also the lower bearing mount on the frame for deformation.
Offline n3303j
  • Ron Cichowski
« Reply #11 on: May 17, 2024, 10:08:54 AM »
And the upper too. BMW /2 I bought had two oval bearing mounts and a wheelbase that was 3/4" shorter than published. Frame Guy fixed the forks. Ball Peen hammer fixed the frame bearing mounts. Then the wheelbase matched published specifications.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Moparnut72
« Reply #12 on: May 17, 2024, 10:37:39 AM »
A hydraulic cylinder repair shop could do this also. They do it all the time.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline texasmoto
« Reply #13 on: May 17, 2024, 06:00:45 PM »
It's not that they can't, it's that they don't want to. I tried to get some machine work done a while ago and every shop I found in Austin was for commercial fabrication, they just were not interested in doing something small scale. I contacted a local shop that does good work but they don't have a press. I wasn't kidding when I said it's difficult to find around here ;)
Offline n3303j
  • Ron Cichowski
« Reply #14 on: May 17, 2024, 06:18:42 PM »
Not sure how much or where your steering tube is bent.
In the good old days when I was a kid (22 ish) I managed to a actually bend the front swing arm on the brake side of my BMW R27 in a panic stop. It was enough that the wheel was crooked and the axle holes didn't align. Was sort of living on the road at that time so my shop wasn't available.
I had a SERIOUS welded link chain that I secured the bike with parked on the streets of Boston. I put a hydraulic jack on the high spot of the swing arm leg and wrapped the chain over the low sides and across the top of the jack. Then pump the jack, release and check; several times until the axle inserted correctly and both wheels were parallel.
I've straightened a number of shafts. It seems they have a bit of memory. They will go back to straight with a bit less effort than will be required to "overbend" them. You can almost feel when the shaft (or tube) is back home. Then you feel it trying to resist the over correction.
Find someone with a hydraulic log splitter and get yourself three hard wood blocks. That should get it done.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline ital4me
« Reply #15 on: May 18, 2024, 07:52:32 AM »
Has it been welded together? If so have the machine shop just make a new one.
Offline n3303j
  • Ron Cichowski
« Reply #16 on: May 18, 2024, 08:24:04 AM »
Try straightening it yourself.
Chances are you won't make it any worse.
Reasonable chance you'll make it better.
Had a "potato chip" shaped steel rim on my BMW /2 (disassembled wheel).
Took it down the basement and put the rim on two blocks at the low side.
Put a 4X4 across the high side and placed a hydraulic jack in the middle.
Put another 4X4 from the top of the jack to the main beam in the basement.
Then proceeded to try and jack up the house.
Needless to say the rim unbent before the house lifted.
Rim did another 50K miles with me before I sold the bike.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline SIR REAL ED
« Reply #17 on: May 18, 2024, 09:33:52 AM »
wow!  That is amazing.  I guess they have all the business they want.
Since the bend is a long way away from the bearing surfaces, a big hammer would probably work just fine.  Or a bit of heat and a small hammer.
« Last Edit: May 18, 2024, 09:36:37 AM by SIR REAL ED »
2002 MZ Skorpion
1994 DR Skorpion
Offline SIR REAL ED
« Reply #18 on: May 18, 2024, 09:37:05 AM »
That is brilliant.  I'm gonna steal that idea.  Thanks.
2002 MZ Skorpion
1994 DR Skorpion
Offline Moparnut72
« Reply #19 on: May 18, 2024, 09:39:27 AM »
You could do it yourself with a hydraulic press. You could get one from Harbor Freight for about $175. Expensive for one job but probably not a whole lot more than what you would have to give a shop to do it for you. Then you would have it for miscellaneous other jobs that WILL come up. I have one in my shop, I hardly ever use it but when I do need one it is standing ready.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline SIR REAL ED
« Reply #20 on: May 18, 2024, 10:45:08 AM »
Texasmoto,
Thinking about this while walking the dogs, I'll bet the steering stem was bent like this when it was brand new.
I'm a mechanical engineer with 3+ decades of machine/tool design experience, and looking at the bend, I can't imagine how that got bent while in service.  Even if the bike was in an accident, the steering stem is supported at both ends by the bearings.  How the middle of the shaft could get loaded to produce a bend there is beyond me.
I am comfortable imagining a machinist at the Guzzi factory thinking: "Wow!  This steering stem blank is bent, but since I am machining the bearing surfaces and threads, as long as the bearing centers are collinear, it does not matter!  No point in worrying about things that are not important and will not be inspected.  So, in to the lathe it goes!"
If you want to straighten it, no big deal, easy job.  Just make sure is it support at the bearing surface so you don't make it worse by bending it where it matters.
If it is a headache to so so, I'd leave it.  From your orginal post, it doesn't sound like a handling problem tipped you off to finding this.  Sounds like a non-existent problem that does not require a solution.
The manufacturing world is a fascinating place!!!  Please keep us informed.
2002 MZ Skorpion
1994 DR Skorpion
Online John A
« Reply #21 on: May 18, 2024, 12:18:47 PM »
I’d be looking for a good used one.
« Reply #22 on: May 18, 2024, 12:25:13 PM »
I agree - complete good used lower "yoke" with stem. Mark @ Moto Guzzi Classics likely has some 562-986-0070.
« Reply #23 on: May 19, 2024, 07:45:00 AM »
I would probably go with plan B if you can't find anyone with a press.  Take a 2 x 4 longer than the stem and a large rawhide hammer. I think the one I have is close to three lbs?  Lay the part on the 2 x 4 with the high spot up and solidly hit it. You should be able to get most if not all of that bend out.  The rawhide will not damage the shaft and the 2 x 4 will not damage the threads.
