Probably an air leak.Check the hose connections between the airbox and throttle bodies, and between the throttle bodies and the engine.In my experience, it has been a problem with the hose connecting the throttle body to the engine.
Throttle cable hanging up?
Throttle cable outer sheath end has popped out of its end support.Patrick HayesFremont CA
Difference was that when cable had popped out of support, idle was high and it had power. Now it is just high but no power.
