Author Topic: V85TT -- Found the oil leak... maybe not...  (Read 28577 times)
Offline brother dave
Re: V85TT -- Found the oil leak... sort of...
« Reply #30 on: August 08, 2024, 12:17:17 PM »
I have a 2021 Centenario.  It seems to consume about 150 CC every 1K miles... so about a quart every 6K miles.  I use Motul 10W60.  Given the rings discussion here and on Adventure Rider I think I will start keeping a closer watch on it....
2007 California Vintage (left the nest)
2018 V7 III Special
2021 V85 Centenario
2022 KLX300
Offline tommy2cyl
« Reply #31 on: August 08, 2024, 04:19:09 PM »
There is value in this thread for me to learn of other owner's rate of oil loss per miles ridden.  The more  owner's that comment, it will form a data base for what may be considered "normal"  or common with the V 85.  Of course there are a lot of variables with temperature, altitude, type of riding
surface and rider throttle input, but still, I would encourage other owner's to contribute their experience to form a general basis so a range can be
considered "normal", and at how many miles oil consumption may have changed noticeably. Any info on how the bike is primarily ridden and location, oil choice,  would only add more to the discussion.  Thanks for any future responses.
« Reply #32 on: August 08, 2024, 05:25:52 PM »
I’ve had mine for over 5 years.  Where is the evidence of bad rings leading to oil consumption? I try to stay on top of this stuff, but have never heard of this.
Offline mondtster
« Reply #33 on: August 08, 2024, 06:13:07 PM »
As another point of reference, I have one of the first V85TTs that made it into the US. I've owned it since new and performed all the service work on it. It has 33,000 miles on it with 5000 mile oil change intervals using either Motul 7100 10w60 or Silkolene 10w60 after the initial service at 1000 miles. There is no discernable oil consumption between changes but the oil turns dark fairly quickly, suggesting to me that the blowby is higher than I'd prefer.
My guess is that the rings don't really go bad but instead get stuck or the oil ring gets plugged up over time. Disassembly, cleaning, and reassembly would probably cure some of the oil consumption complaints that are blamed on bad piston rings.
Online Bulldog9
« Reply #34 on: August 09, 2024, 07:36:35 PM »
This has been an issue. Not universal, but I have seen several issues on the various threads.
MGNOC#23231
« Reply #35 on: August 10, 2024, 12:04:53 AM »
Is there a published oil consumption limit in the owners manual?
Offline Vagrant
« Reply #36 on: August 10, 2024, 09:30:58 AM »
Having had the issue in my 2020 my suggestion is.
If under warranty and using more than 1 ounce in 1000 miles, get it into the dealer and bitch. Make him do a compression and leak down and call Piagio especially if it's a 19-21. Keep the paperwork from that visit.
If out of warranty, put in oil as needed but if it starts running ratty like low power, missing etc. Get ready to put rings in it.
JMHO, but I bet the cheap (Chinese?) rings will come back to haunt them. Maybe even as bad as past cam/lifter issues.
That being said, once fixed, I traded my 20 for a 22 and just bought an extra 23 to take to Az for the winter. I love these things.
« Last Edit: August 10, 2024, 09:32:42 AM by Vagrant »
Offline DesertPilot
« Reply #37 on: October 03, 2025, 01:10:01 PM »
Update: 2025
Oil consumption on my 2020 V85TT has continued to get worse and now, at 18,0421 miles, a year after I began this thread, the bike is only getting less than 1100 miles/qt.  No matter what the local shop might say about, "Some oil consumption is normal for air-cooled engines," this seems a fair bit more than 'some' or 'normal'.
With the next big service internal coming up, and the bike long out of warranty, my options seem to have become"
1) Do the service myself, keep pouring oil in for the next few months, see if things deteriorate to the 'you have to bring spare oil along on a ride' point.  Which, with only 250 ml between the fill marks, they're already approaching.
2) Do the service myself, then take the bike to the shop, point to the oil consumption figures, and say, "What's all this then?"
3) Take the bike to the shop, point to the oil consumption figures, and say, "What's all this then?" have them get things sorted, and don't let my wife see my next bank statement.
4) Other.
Question: do any of you know what VIN numbers were purported to have oil ring problems?
Online PJPR01
Re: V85TT -- Found the oil leak... maybe not...
« Reply #38 on: October 03, 2025, 02:15:40 PM »
Sounds like a trade in discussion may be in order if the dealer you bought it at and is currently servicing it considers this normal.  If that's the case, they should value it at full price...if not, then they should be able to fix it.
What's the worst case scenario?  Tearing the bike apart and putting in new rings?
I know it's a long shot, but have you tried for one oil change to go down to 10W-30 or 10W-40 and see if that makes a difference on consumption.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline DesertPilot
« Reply #39 on: October 03, 2025, 06:44:31 PM »
Worse case scenario would be swapping in new rings, as you say.  Which I'm not in a real hurry to do myself because it's outside the range of jobs I usually do so I can't guarantee getting it right..  This means that one way or another, I'll have to talk with the shop, either to schedule the work or arrange a trade.  Thanks for your comment!  It helped me boil this all down to that one simple trade-off.  I'll have to think this one over.
Offline Vagrant
« Reply #40 on: October 03, 2025, 07:45:38 PM »
FYI, as I recall Guzzi only allowed 3 1/2 hours for the job. No way It could be done in that time as far as I'm concerned but might be worth paying the dealer to do it. A big wet dream perhaps but if he has a good relationship with Guzzi he might get a tiny bit of "policy adjustment".
« Reply #41 on: October 05, 2025, 01:01:33 PM »
Another place to look is the intake valve guides. Oil can be pulled past them, some builders fit seals on them. Maybe it has that problem as well as rings. I’d try conventional oil that doesn’t burn off as clear as synthetic so you can maybe see some evidence where it’s being consumed.
Offline DesertPilot
« Reply #42 on: October 08, 2025, 12:15:31 AM »
I too have wondered.  In a perfect world I'd get someone to follow me to see if the exhaust was smoking as I rolled on or rolled off the throttle.  In this less-than-perfect world, I suppose I could try to Do Something Clever with a GoPro, but my odds of success seem slim.
Current plan is to do the 18.6k service myself later this month, keep track of oil consumption a bit longer, then Do Some Serious Thinking.
