Author Topic: 1200 sport steering  (Read 2037 times)
Offline jamesb
1200 sport steering
« on: August 10, 2024, 02:13:13 PM »
i am looking for opinions .i have a 2 valve 2007 1200 sport which is very much standard and thanks to all the info on this site runs very well. the issue i have is that when coming to a stop (car park speeds ) the bike has a tendency to turn quickly into the right. its caught me a couple of times and i thought it was just me ,but when getting an mot the other day i mentioned it to the tester and he replied that he had heard that from another guzzie customer so what is your experience? or have i an issue , its got new head bearings and swing arm bearings. is there a preferred front tyre?
Re: 1200 sport steering
« Reply #1 on: August 10, 2024, 02:20:16 PM »
Good idea on tires. I have noticed some bearings have a tendency to like one side more than the other. Re-adjust after break-in is required. Tires will make it feel more or less noticeable.
Offline Bulldog9
« Reply #2 on: August 10, 2024, 03:43:20 PM »
Are you using your front brake at those speeds?  If so, try using the rear only. I would also double check the steering head bearings and bushings for proper grease and adjustment. Tires are a possibility, they can be weird when at the end of their life.
« Last Edit: August 11, 2024, 10:28:00 AM by Bulldog9 »
MGNOC#23231
Offline jamesb
« Reply #3 on: August 11, 2024, 01:40:31 AM »
thanks for your replies. yes bulldog9 i was using my front brake at the time. my riding mate had also suggested that and i have addressed it, but he experienced it as well when he gave it a trial. its got michelin road 5s on. there are new steering bearings on it, should i preload them up some? there is no play
« Reply #4 on: August 11, 2024, 09:18:30 AM »
Are both your brake calipers on the front operating correctly ?
Offline jamesb
« Reply #5 on: August 11, 2024, 11:09:12 AM »
good one huzo. ill have to dig in to that, ive not had any problems braking from speed but ill investigate and report back
Offline Bulldog9
« Reply #6 on: August 11, 2024, 11:48:02 AM »
I can't see this as the issue, afterall there are tons of single disk front brakes, and the wheel is not known to turn. I'm thinking this is technique not mechanical.
MGNOC#23231
Offline jamesb
« Reply #7 on: August 17, 2024, 03:10:55 AM »
i have looked at the brakes and everything seems fine so perhaps it is me. ill see how things go. thanks for your thoughts
