Author Topic: Norge factory fork oil wt & spring rate?  (Read 1463 times)
Offline brider
« on: September 27, 2024, 07:20:47 PM »
I hesitate to even start another Norge Fork thread, but there is just nothing conclusive about the factory fork oil or spring rate that I can find. Lots of threads describing what weight oil people change TO, or what springs they change TO, but nothing about the baseline configuration. I am not a fan of just installing a kit, without knowing what my starting point is.
I DO have an e-mail pending @ Hyperpro asking what their kit for the Norge consists of, so maybe they'll be some help...
But in the meantime: My '07 forks are apart and appear to be amazingly simple. My complaints are typical, too much dive, but the damping rates don't seem too bad, and I suppose heavier oil may improve that, but without knowing how the damper was designed it's hard to tell. I think a simple spring upgrade would satisfy me but again, I'd like to know what spring rate I'm starting with.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Online PJPR01
  • Norge, Scura, Griso
Re: Norge factory fork oil wt & spring rate?
« Reply #1 on: September 27, 2024, 08:07:21 PM »
I don't recall the stock spring rate, but I did the Hyperpro upgrade of springs and oil and it does make a very nice difference in handling.  I don't think you'll be disappointed even w/o the actual specs.  The original weight of fork oil is likely in the owner's manual however...I don't have it nearby at the moment.
Paul R
2015 Red/Black Griso
2008 Silver Norge
2002 V11 Scura
Offline brider
« Reply #2 on: September 28, 2024, 07:43:45 AM »
Thanks, I guess I should've looked in the owner's manual, but the shop manual says nothing about viscosity, only volume.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
Online PJPR01
« Reply #3 on: September 28, 2024, 03:54:28 PM »
Going off memory here….I think there is a 5 weight difference between stock oil viscosity and the Hyperpro oil…with the Hyperpro being heavier (more resistance)…so it’s either 15 wt vs 10 wt…either way you will enjoy it!  Coupled with a good aftermarket rear shock/spring combo and the Norge rides like a sport bike in the curves but still very comfortable for long distance riding.
Paul R
2008 Silver Norge
2002 V11 Scura
Offline brider
« Reply #4 on: September 28, 2024, 04:27:28 PM »
I forgot to mention that the PO of my Norge installed a different spring, or did SOME kind of rear shock work as identified by several riders at a rally I took it to shortly after I bought it. The rear seems invisible to me, no issues at all, feels great. But those forks sucked from the first time I touched the ft brake when wheeling it to the trailer when I bought it.
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'72 Red Eldo
'74 White Eldo LAPD
'06 Gas Gas EC300
'86 LM IV
Offline Stevex
« Reply #5 on: October 04, 2024, 10:58:02 AM »
There is no common ground for fork oil weight between manufacturers.
If you want to keep the same viscosity oil as oem recommended, using a different manufacturer you need to use a CentiStokes table.
https://www.peterverdone.com/wiki/index.php?title=Suspension_Fluid
https://motoiservices.com/en/suspension-oil-equivalence-chart/
Not infallible, but a damn sight more accurate that going by weight value.
