Eldorado problems
Topic: Eldorado problems (Read 2901 times)
Mor
Hatchling
Eldorado problems
October 09, 2024, 08:39:52 AM »
Last Edit: October 20, 2024, 03:45:04 PM by Mor
guzzisteve
"Just Ride It"
Re: Eldorado problems
Reply #1 on:
October 09, 2024, 01:30:52 PM »
Might be getting air up the threads of the bolt stuck in the line, remove line & cap the spigot. All I got, sounds like air getting in.
Clean throttle body w/cleaner that's OK for the sensor. Oil will goo things up.
kingoffleece
SplitWeight(tm) seat covers
Rated 5 STARS Motorcycle Consumer News
Reply #2 on:
October 10, 2024, 09:19:21 AM »
Correct. Valves can cause that.
guzzisteve
"Just Ride It"
Reply #3 on:
October 10, 2024, 09:29:42 AM »
How about the bolt in LH manifold, they should both be capped off w/bolt. I clean my throttle bodies on the EV 1100 every 10Kmi same time I clean the K&n air filter.
moto-uno
Reply #4 on:
October 10, 2024, 07:57:23 PM »
The correct oil level on those models was no more than half way between low and full .
And I always found that spraying WD-40 around intake sealing areas would high light any intake leaks .
Boy did I ever enjoy the motor on my 2018 Eldorado.
Moparnut72
Reply #5 on:
October 11, 2024, 09:37:40 AM »
Yes Peter, I really like the motor in my Audace. Too bad I could no longer ride it. The motor in my V100 is very similar, lots of low end power and plenty of scoot up top.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Eldorado problems
