Author Topic: Upswept Silencers  (Read 1714 times)
Offline remfanuk
Upswept Silencers
« on: October 09, 2024, 10:29:39 AM »
I have a 1979 Mk2 V50 and would love some upswept silencers on it probably similar or a bit more upswept than a Le Mans.  Anyone know where I might find such things please?  I am presuming that Le Mans silencers don't fit on to the standard V50 pipes?  Thank you.
Re: Upswept Silencers
« Reply #1 on: October 09, 2024, 01:23:49 PM »
Here is a place I got pipes from, high quality, you want Monza pipes they have a upswept bend in the back.
http://www.keihan.co.uk/
Offline testa_di_formaggio
« Reply #2 on: October 09, 2024, 11:58:34 PM »
You might have to shim Monza cans to fit. Many years back, when I wanted cans for a V50, I was sent same for a V50 III, with collar shims, as the V50/II had smaller diameter pipes than the III and the Monza. Long time ago, could be wrong. But probably your best bet, worth investigating. There isn't going to be much of anything else off the shelf for what you are trying to do. Otherwise, custom made.
TdF
Offline remfanuk
« Reply #3 on: October 10, 2024, 03:39:49 AM »
Thanks, I will look into this.  Maybe Monza is the way to go as I don't want them so upswept that I have to make an ugly mount for them.  Going to go for black I think.
