Author Topic: ABS light NorgeGT, sorted (for now)  (Read 3024 times)
Offline theoneandonlymin
« on: October 25, 2024, 11:50:48 AM »
 So I've had a search here and can't find the answer.
Went out this morning and no speedo and  ABS  light stayed lit.
Home and have cleaned both speed sensors and tone wheels.
Then regarding front sensor
1/  disconnected
      abs light on constant
2/  reconnected
     light flashing
3/  rotate wheel
     Speedo now works, got it up over 5mph
     Light flashes
4/ disable abs
     Light on constant
     Speedo works
Heading to the rear one now.
I presume , ha, if the Speedo works the sensor is working.
Cheers
« Last Edit: October 27, 2024, 02:54:33 PM by theoneandonlymin »
Re: ABS light NorgeGT
« Reply #1 on: October 25, 2024, 05:28:44 PM »
Yes, you are doing it correct if ABS unit works correctly. Most often it's the sensors & not the unit. I think there is an ohm reading also.
« Reply #2 on: October 26, 2024, 10:39:34 AM »
My question is....having spun the front wheel and seemingly the speed sensor is working, do both wheels have to reach speed at the same time for the ABS light to go out ? It's hard for me to replicate that on the bench.
Cheers
« Reply #3 on: October 26, 2024, 11:24:12 AM »
I thought I would have a look at the schematic
https://www.thisoldtractor.com/guzzi007/schematics/2007_Norge_ABS.gif
Of course it doesn't shed any light.
I have trouble with the ABS light on my 2014 V7III Special
If I stop and cycle the ignition switch it usually goes away.
The speed sensors are both wired to the ABS controller so the speedo must get a signal via the CAN Bus from the ECU
« Last Edit: October 27, 2024, 07:50:02 PM by Kiwi_Roy »
« Reply #4 on: October 27, 2024, 02:53:50 PM »
Went to road test it this morning and no start so lifted the tank and found a broken male inside the 6way coming from RH switch cluster. Sorted that then rode down my back passage and ABS light went out. Speedo works.
My thinking is as the rear speed sensor had quite a big of crud attached to it it upset the whole system. So even if we consider the front sensor to be the speedo it must need the rear sensor to be operating correctly.
No, I haven't spun the rear wheel to seeing that gives a speed reading. But I will.
