Author Topic: NGC - Motorcycle lift when not in use?  (Read 12825 times)
Online Vagrant
Re: NGC - Motorcycle lift when not in use?
« Reply #30 on: November 27, 2024, 07:21:47 AM »
Brider, I just line up the 1/2 - thickness cement block on the left side of the lift and it's easy to walk right up without getting out of balance.
Offline guzziart
« Reply #31 on: November 27, 2024, 09:04:02 AM »
FWIW, I use a small plastic one-step to give me level footing to deploy the bike center stand once on the lift.
- Also, to decrease the ramp angle I place a footlong 2x4 or 2x6 underneath the lower ramp edge to make rolling the bike up the ramp easier.
- Also, to get the bike up onto the center stand I place a footlong 1x6 or 2x6 in front of the rear tire, roll the bike on the footlong and go for the C-stand.
As I age I'm trying to work smarter not harder.
Happy Holidays!
Art
Offline dguzzi
« Reply #32 on: November 27, 2024, 01:23:28 PM »
  My lift has casters and so I need to figure a way to chock them so the lift stays put. I don't want to remove them because they make the lift so easy to move when its necessary. Its those small diameter steel wheel casters.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
« Reply #33 on: November 27, 2024, 02:16:16 PM »
Maybe replace the casters with a locking version? Just make sure the replacements can take the weight.
Online Vagrant
« Reply #34 on: November 27, 2024, 03:45:58 PM »
If it's a HF ramp there are adjusters underneath to lock it in place.
Offline Perazzimx14
« Reply #35 on: November 27, 2024, 04:13:20 PM »
No matter what brand lift there should be a way to raise lower the casters.
Offline vintagehoarder
  • Cycle Hoarders
  • Ride to Eat, Eat To Ride
    • Facebook Page
« Reply #36 on: November 28, 2024, 08:33:08 AM »
I have a harbor freight and my vehicle has the clearance that I can just park over top of it.
Cyclehoarders Garage
2021 Honda CT125 Trail Cub
2018 Triumph Tiger 800
2014 Moto Guzzi V7 Speical
2009 Vepsa GTS 250 ie
1986 Yanaha FZX700 Fazer
1981 Honda CX500 Deluxe
1973 Moto Guzzi Eldorado 850
1969 Yamaha YAS1C
LaGrange, KY
Online Vagrant
« Reply #37 on: November 28, 2024, 02:53:58 PM »
Funny! I park my Sammy on top of mine too. Problem is there is a big oil puddle to clean up each time.
Offline dguzzi
« Reply #38 on: November 28, 2024, 06:02:02 PM »
  This is a scizzor lift, not a HF, I added the casters myself, they are not adjustable. No space to add a crank down lift to lock the position...
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline guzziart
« Reply #39 on: November 29, 2024, 11:17:39 AM »
Maybe try placing 4 wood blocks under the lift to raise it enough to get the casters/wheels of the ground.  Since my garage floor has a slight slope to the sewer, I shim my lift accordingly so it's level.  I use a 2x4 and a crow bar to lever the lift up then place the appropriate sized wood shim underneath the front caster (and screw lock) & rear wheel.....in your case it would be underneath the lift frame, I reckon.
Art
Offline dguzzi
« Reply #40 on: November 29, 2024, 05:50:31 PM »
    That could work! As long as the shims don't slide...I could attach some sandpaper for friction.  Thank you guzziart
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Offline Perazzimx14
« Reply #41 on: November 30, 2024, 08:38:14 AM »
Or a piece of rubber mat under ach shim for a more long term solution.
Offline guzziart
« Reply #42 on: November 30, 2024, 10:33:57 AM »
Good to know and thanks for the pic!  I've always though my HF lift might be capable of being stored under our pick up truck but after seeing your Sammy over it I'm thinking it definitely will.
Art
« Last Edit: November 30, 2024, 10:35:27 AM by guzziart »
Offline guzziart
« Reply #43 on: December 08, 2024, 02:06:56 PM »
In my shop no flat surface goes unused, it can always be used as a workbench.
Same here! :laugh:
  • Cycle Hoarders
    • Facebook Page
« Reply #44 on: December 09, 2024, 02:39:41 PM »
i tuck my Samurai in for the winter, so I straddle mine and park over it.  The Samurai has the clearance to be able to.
1969 Yamaha YAS1C
LaGrange, KY
