Author Topic: Indicator warning light.  (Read 3445 times)
Offline GuzziNZ
« on: November 25, 2024, 05:05:23 AM »
I would like to fit a bright LED near the instrument cluster to show when the indicators are going on my 850T.
Can I just Tee off the LED feed wire to both the left a right indicators and  fit a blocking diode into each wire or just use two LEDs, one for each indicator.
Re: Indicator warning light.
« Reply #1 on: November 25, 2024, 10:04:03 AM »
Yes. Greg Bender has supplied me with a simple harness for this purpose. Many times I repurpose the high beam warning light for the signals, rather than adding more.
« Reply #2 on: November 25, 2024, 01:18:33 PM »
Yes, just use a diode from each direction feeding a lamp to chassis.
I had a buzzer for a while wired the same way but my friends said the could hear me coming blocks away.
I also have a lamp that indicates when my brake light is ON, its wired to the front brake switch to chassis (also lights if the rear brake is applied)
« Last Edit: November 25, 2024, 01:27:46 PM by Kiwi_Roy »
Offline StuCorpe
« Reply #3 on: November 25, 2024, 02:22:36 PM »
This is what I did on my 03EV.  Blue LED for left and right turn signal.  They are very easy to see in bright sunshine and maybe a bit to bright at night.
