Author Topic: Driving lights recommendation for 1200 Sport  (Read 5047 times)
Offline willowstreetguzziguy
« on: January 04, 2025, 05:56:15 PM »
I’m looking to add driving lights to my 2008 1200 sport. The stock high and low beams are the worst of any bike I’ve ever owned. I’d like to find a set that I could mount on my forks that would be on all the time and provide both great nighttime lighting as well as daytime visibility to other drivers. Any recommendations?
2008 Guzzi 1200 Sport
Offline 73 sport
Re: Driving lights recommendation for 1200 Sport
« Reply #1 on: January 04, 2025, 06:42:24 PM »
     Check out Denali D3, D7 lights @ Denali Electronics.
Offline ridingron
« Reply #2 on: January 04, 2025, 08:24:37 PM »
Just a fore warning. They're pretty proud of their products!
Offline guzzi ride
« Reply #3 on: January 04, 2025, 09:22:54 PM »
I have Motolights on my Norge which are basically the same forks.
Offline bigbikerrick
« Reply #4 on: January 04, 2025, 09:38:41 PM »
The Denalis are great, but pricey. Has anyone got any "budget friendly" recommendations?
Rick
Online frozengoose
  • To eaches his onus...
    • smiles from nowhere
Big Jon
Jerry Zee
« Reply #6 on: January 05, 2025, 05:26:49 AM »
I've moved the same set of Denali D2 that are 10 years old to three different bikes-still going strong.
I'd say that's great value for the money.
Offline johnwesley
« Reply #7 on: January 05, 2025, 09:07:11 AM »
 :whip2:
Rick
What size are you looking for? Any special mounts you need the light to come with?
I’ve run several cheap leds on my bike and my fave is a 4” set that are high and low beam with a good cut off.  I wire the included relay into the headlight harness so that the high beam switch works the aux lights.
https://a.co/d/j2DNgvu
Arkansas MGNOC rep
2003 cal ev custom build/ adv scrambler thing
2000 Quota
1989 cal III FF
1985 cal II
1977 T3 California
Offline Bulldog9
« Reply #8 on: January 05, 2025, 09:45:55 AM »
I've had these mounted to my Fork for 3 or 4 years. I used a
 3/4" aluminum spacer and longer bolt to attach the bracket to
one of the fender Mount bolts on the fork. They are helpful to light
up the driving area, but also helps with being seen.
I wired them directly into the GPS power lead.
$30 from Amazon.
MGNOC#23231
« Reply #9 on: January 05, 2025, 12:03:34 PM »
Bulldog9, I currently have a pair that look like the ones you mounted. The light output is OK, but the wires that come with the lights are so thin ,with such few filaments, that is hard to attach connector/solder. Thanks Guys for the other suggestions. Those 3.5" for 40 bucks seem pretty nice for the $. those with high/low beam seem pretty darn cool, I like those for my Convert. They are a bit too "modern" for my eldo.
Thank you all,
Rick
Offline Huzo
« Reply #10 on: January 05, 2025, 12:54:25 PM »
I put these Denali’s on my V85.
They are superb, first time they save your ass you’ll forget the price.
Offline Perazzimx14
« Reply #11 on: January 05, 2025, 04:10:34 PM »
Between me and a couple of friends we have used 15 or 20 sets of these  dual color LED on various motorcycles with excellent performance and very cost effective. Currnetly they are about $22 a set on Amazon but I have gotten them as inexpensively as a couple of dallars each on AliExpress. While I'm sure theyare not as good as a $1,200 set of Clear Waters at 50x less costly they are not 50x less effective.
https://www.amazon.com/Zmoon-Motorcycle-Projector-Spotlight-Compatible/dp/B08GS4QTZN/ref=sr_1_5?crid=2UCQPPE87QQYK&dib=eyJ2IjoiMSJ9.wwSiv3yg_T9OFtI6A6AdKKfAx2c-aE0A24Mzds2Yw51QEcZTo8Je40wa8PYuy7szJv3GoYNFbn72ESNC1pOj0bNm5bcIdj-w735lK8J9DKA3ZeaaTVJJ1JLKwY8lLRIsNJwq95jPiiee95Bg0hkRydZ_lCrkJrrAp_5bc3vzq3E6gVMjuO0U8Ev5hxuhZoHhnRTdicfVDuxYdDmuS4PpmcBWI_TUPe2urzBRT9c1qeNtGwworLnlEfO27C_OVMDQMAzivPe6pPxEg25ZlaxNyy_D29tUM-L7Vqc3ZsY_U7XAakRVbksBFXPjTG48XXrrKyJiWA6g8Dyb9OXtOCqlXrTRX0OFvjSE6FJF-2BCb6pwA1ylzJKln3jB9CistbRWgOop4C3D15ROy2oKP2WSzo2QutCagORlXrQW3qUoADCePYOCz84_EurlWsgicvmz.sMbF37E1WmZNwiSXztgIdTGEYTNMSgLasj3cJFfugbk&dib_tag=se&keywords=1%22+MIni+LED+dual+color+driving+lights&qid=1736114966&sprefix=1+mini+led+dual+color+driving+lights%2Caps%2C185&sr=8-5
Here is a set I recently put on my another GS with a on/off/on switch going form white to yellow is as easy as toggling the switch.
« Last Edit: January 06, 2025, 05:59:17 AM by Perazzimx14 »
Offline Huzo
« Reply #12 on: January 05, 2025, 07:08:46 PM »
I always felt that lights are like helmets and tyres.
If you have a $10 head…?
Get a $10 helmet.
Offline bronzestar1
« Reply #13 on: January 05, 2025, 11:26:41 PM »
I'd get LED driving lights that have just a single bulb.  I've seen LED headlights that have so many bulbs in them they look like bug eyes.  If you want driving lights, you'll want the highest number K rating you can find, maybe 6500K.  They don't need to be any higher wattage than 55, although there are some out there that are 65w and 100w.  Mounting them shouldn't be a challenge, if you have some aluminum flat stock and mounting hardware available.  I think the most challenging part will be wiring them up.  If it was me, I'd wire them to a switch that's easy to reach, some source that's hot only when the key is on.  Probably good to mount a relay as well, just in case.  I used to have an MV Agusta F4 750 that would overheat, so part of my attempts to fix that was to wire a bypass switch for the radiator fans, so I could turn them on earlier than the t-stat would.  Found a small toggle switch that I mounted on the side fairing, worked wonders (along with a new water pump, metal radiator fan blades, and using Engine Ice coolant).
Offline Perazzimx14
« Reply #14 on: January 06, 2025, 06:11:37 AM »
Get a $10 helmet.
I've always felt like paying more doesn't not automatically equal getting more. YMMV.
Offline Bulldog9
« Reply #15 on: January 06, 2025, 03:06:52 PM »
All depends on "WHY" you are mounting the additional lights. I mount them more to 'be seen' than to see better at night. Even the
cheapo Chinesium LED's I have been mounting on my bikes the last 3-4 years do a decent job, especially lighting the 10-15' in front of the
bike when I am forced to ride after the sun goes down. YMMV....
Oh, and comparing lights to helmets is a non sequitur.
Random story.......... I mounted a pair of 50W halogen lights to the bottom of my Rifle Fairing with a switch and relay to my XS1100 back in the
late 80's-90's.  I had to watch the voltmeter and be judicious with their use because these things would suck the life out of the battery, even when running at speed.
They were as bright as all get out though, and my riding buddies joked they were like lasers and vaporized traffic from in front of me, chase wildlife and small
children from the road, etc etc..... Came in VERY handy on my almost monthly IBA runs. But the ancient charging system of the Yamaha couldn't handle the draw.
MGNOC#23231
Offline Huzo
« Reply #16 on: January 06, 2025, 03:21:45 PM »
Correct P.
I can buy two bowls of soup from the same chef, paying $5 for one and $50 for the other.
But when you said (correctly) that it’s not an automatic guarantee that you’ll get a better product I’m bound to agree.
But if I asked you are your BMW’s better than Kwong Chi Phang bikes from China because the Beemer is more expensive ? Answer is no.
The BMW is not better because it’s more expensive….
It’s more expensive because it’s better…
« Reply #17 on: January 07, 2025, 04:19:05 PM »
Perazzimx14, excellent recomendation,  look nice,and very inexpensive. I have got to give those a try.
thanks
Rick.
Offline Perazzimx14
« Reply #19 on: January 07, 2025, 07:33:41 PM »
thanks
Rick.
You will not be disappointed. I would also suggest you get a couple red Posi-Tap couplings saves from soldering and makes connecting the wires from the LED to the power and ground wires a breeze.
I've also been liking these switches off Amazon. They are on/off/on and mount to the handlebars.
https://www.amazon.com/dp/B09Z7PN34P?ref=ppx_yo2ov_dt_b_fed_asin_title
« Last Edit: January 07, 2025, 07:37:47 PM by Perazzimx14 »
« Reply #20 on: January 08, 2025, 11:46:19 PM »
Thank you Perrazimx14. thats a nice, clean looking switch, and for a good price. I cant remember how many times I have searched for a  simpleclean looking handlebar switch like that, +1 on the posi taps.Thank you Sir!
Rick D
Offline Perazzimx14
« Reply #21 on: January 10, 2025, 08:25:11 AM »
Rick D
I have used several of these switches and they have been flawless. The last one I purchsed I got everything wired up and found the switch to be faulty and would only work on one circuit. It was a great reminder if possible to bench test to verify operation prior to assembly. I got in the habit of bench tesing LED's prior to installation as one time I had one (1) dual color LED that would only light the white circuit and not the amber. Taking 10 seconds to touch the leads to the battery terminals to verify both colors work can save lots of rework. Same with switchs.  A continiuty meter a few seconds can save a lot of headache.
« Reply #22 on: January 10, 2025, 01:55:45 PM »
Good advice! Thank you
Rick
