Author Topic: My "Project 2025" - 1980 Moto Guzzi V50 II  (Read 125026 times)
Offline vxn750
Re: My "Project 2025" - 1980 Moto Guzzi V50 II
« Reply #30 on: January 15, 2026, 06:08:22 PM »
If you remove it, you can check it for pitting on the sealing face an also that all orifices are clean. You can clean the visible part if it with a brass brush on a dremel or similar to get rid of the remaining rust. If you then polish it, it will be reasonably resistant against new rust. Then again, a new one probably does not cost the world.
I’ll soak it overnight and take a closer look.
Definitely going to look into purchasing new ones 👍🏽
***I checked on MG Cycle and it’s only $10 for a two pack of bleeder nipples. Done!***
« Last Edit: January 15, 2026, 08:30:37 PM by vxn750 »
2004 Breva 750, 1980 V50 II, 1974 850T Custom (aka Sawbone’s Roadster)
Offline DoubleGuzzi
« Reply #31 on: January 17, 2026, 01:04:11 PM »
Yeah, even cheapskate me, changed all of them for new.  :shocked:
I also went down that path, then thought splash out.
« Last Edit: January 17, 2026, 01:08:26 PM by DoubleGuzzi »
Nearly natural progression..
Offline vxn750
« Reply #32 on: February 01, 2026, 12:48:37 AM »
I’m pretty pleased with how my first brake caliper rebuild job went. The caliper cleaned up nicely, no extra parts in the end and everything fit back together as it should. I’ll know for sure when I get the whole brake system going. So far, so good.
Offline wirespokes
« Reply #33 on: February 06, 2026, 11:44:26 AM »
When caliper pistons don't want to come out, I resort to the grease gun. It's never failed to work.
Offline vxn750
« Reply #34 on: May 31, 2026, 12:34:00 AM »
Quick update:
https://www.facebook.com/reel/1523709539403450/?fs=e&s=TIeQ9V&fs=e&mibextid=wwXIfr&fs=e
I took it as far as I could and decided that if I wanted to ride my V50 sometime within this decade, I outta just take her to Mark.
 :bike-037:
(PS Bike #11 was my ‘04 Breva 750  :cool:)
Offline DoubleGuzzi
« Reply #35 on: June 04, 2026, 08:47:10 AM »
Started to feel sea sick watching that vid. for a minute! Got outta there, sharpish.
Was surprised I could even view it without logging in.
