Author Topic: Trading the V85….  (Read 2121 times)
Offline inditx
Trading the V85….
« on: February 02, 2025, 07:35:39 PM »
Yep, trading my 2023 for a 2016 BMW R1200RS.
I’ve had a few Beemers but no wet heads so, here we go!
I’ll report back after a bit and will stay connected here even though I’ll be Guzziless for the first time in a bit.
I might have a few take offs and I’ll post them up if/when I do.
RideOn!
inditx
inditx
This is the day.....
Offline Clifton
Re: Trading the V85….
« Reply #1 on: February 02, 2025, 09:14:02 PM »
Enjoy your new RS, they're very good motorcycles. I had a 2016 R1200RS and while I loved the looks and wind protection was good I just couldn't bond with it even after getting the riding position improved with slightly lowered pegs and bar risers. A minor thing but I also didn't care for the instrument display.
24 Stelvio
21 V85TT
20 XT250
14 CB1100
08 1200R Sportster
93 R100R
Offline Perazzimx14
« Reply #2 on: February 03, 2025, 11:39:58 AM »
RideOn!
inditx
If you are a DIY tye for maintnence the wetheads are not complicated and the even the valves are not bad to check/adjust. A $40 TDC tool is nice but not necessary and a steel ruler as a straight edge and a set of feeler gauges round out the speciality tools. Valve shim kits are avalaible off Amazon for around $40.
As for fluids I know the 1250 call for 70W-85 GL5 gear oil and from the dealership a 200ml bottle is priced like it's saffron. The good news is if you head down to the local Dodge dealership they have Mopar branded 70W-80 GL5 for about $19 a quart. A small animal water bottle (BB in the spout removed) or a hair dye bottle with graduations are great for refilling the final drive. Remember to use 180ml of oil in the FD. No more no less.
Engine oil a 5W-40 of your choosing coupled with a HiFlo oil filter.
Brake fluid - is DOT4. I use SuperTech or Prestonewhatever is cheapers or in stock. You can spenda fortune on exotic DOT4 LV brake fluid but unless you are running the IMO its overkill.
A GS911 or Motoscan software and a bluetooth OBD Link LX BT adapter will take care of service lights reading and clearing codes + a bunch of other stuff.
As a side note the drive shaft on the 1200/1250 watercooled bikes are now warranted for the life of the vehicle. Testing and replacing at specific intervals is all handled by BMW at thier cost. I would still not hestate to check the spline lube especially on th elower U-joint and if it dry or in need of being refreashed pick a spline lube and apply sparingly. Once my supply of Honda Moly paste 60 was consumend I bought a cartridge of Wurth SIG3000 that will last me several lifetimes. While technically not "spline lube" it works a treat. It sticks like dog sh!t in a vibram boot sole, resist pound out and sling and is heat tolerant. If you'd like a ration I can fill plastic tube that held epoxy putty and send it to you. Flux brushed from Harbor Freight maes excellent disposable applicators.
Its also not a bad idea to pull the valve covers and have a look at the cams. There were some hardening issue on some of the 1200's so catching it sooner than later is best, especially if you bike is coming with a warranty.
Good luck and enjoy
« Last Edit: February 04, 2025, 10:16:49 AM by Perazzimx14 »
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline inditx
« Reply #3 on: February 03, 2025, 05:59:56 PM »
Thanks so much Perazzimx14, I was hoping you’d chime in since you've had a fair amount of Beemers.
Appreciate the info very much.
Jack
inditx
Offline Perazzimx14
« Reply #4 on: February 04, 2025, 10:20:26 AM »
Jack
Glad to help. I addded a few thing to my original post and also will mention the Beemer Bone Yard, Ted Porter and Max BMW are great resources for parts and consumables. Max BW has a really good parts fiche:
https://shop.maxbmw.com/fiche/partsfiche.aspx
Cheers,
P-14
Offline inditx
« Reply #5 on: February 04, 2025, 07:57:48 PM »
Absolutely!
I’ll pm you my address.
I forgot about Max and Ted Porter.
Cheers!
inditx
