Author Topic: V7 unsightly throttle gap  (Read 2957 times)
Offline egschade
  • Eric S - MGNOC NJ Rep - mgnocnj.forumotion.com
« on: February 08, 2025, 04:06:25 PM »
Recently installed my favorite Biltwell grips on the Carbon and found that the OEM grips are molded to cover the end of the throttle tube. The Biltwells leave an unsightly gap as I suspect others will. Any suggestions on how to fill / cover the gap?
The elder Eric in NJ
2016 V7 Stornello #394
1971 Honda SL350
Past Guzzis:
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Online DoubleGuzzi
  • '19 V7III CS; '79 V50; (Triumph S400)
Re: V7 unsightly throttle gap
« Reply #1 on: February 08, 2025, 05:19:49 PM »
Cheapo foam/soft grip, cut to the right length? I had one on the opposite side of the grip 'ledge', to ease my throttle grip on the Bonnie.
Pop it in some warm/hot water to soften.
« Last Edit: February 08, 2025, 05:25:21 PM by DoubleGuzzi »
Nearly natural progression..
Present: V7III CS, (V50II).
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: February 08, 2025, 05:29:20 PM »
Wow, those grips are really that short?? Any chance the grips just aren’t quite all the way on? Or, maybe if there’s an end cap on the grip, trim the end cap to allow it to slide on a little further?
Otherwise, I would just throw the bike away and get another one that the grips fit.
« Last Edit: February 08, 2025, 06:54:36 PM by Dirk_S »
Offline egschade
« Reply #3 on: February 08, 2025, 05:54:14 PM »
snip
 :grin:
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
Online DoubleGuzzi
« Reply #4 on: February 08, 2025, 05:54:25 PM »
Wow, there’s grips are really that short?? ..
Many times, the 'ledge' isn't shaped to fit over that bit of the throttle tube - I've seen that on a few bikes. Sometimes, it's possible to squeeze it up to that white portion, though I seem to recall just cutting that (superfluous) bit of the throttle tube off.  :shocked:
I'll assume you cut the closed end off, if they are closed, to refit the end weights.
Thanks, @egschade - I'll look out for that, when it comes to fitting my heated grips!
« Last Edit: February 08, 2025, 06:19:23 PM by DoubleGuzzi »
Online jhem68
« Reply #5 on: February 08, 2025, 09:48:41 PM »
The grey and black Domino grips I installed on my V7III Milano had that same shortcoming. But I live with it as the grey closely matches the paint and the grips are really a very comfortable compound.
Apparently the Guzzi throttle tube is a little different length than most.?
Offline 73 sport
« Reply #6 on: February 09, 2025, 10:45:51 AM »
      On my '74 Sport, I have a Tomaselli "Daytona" throttle with "Biltwell Renegade" style grips. They are 6 3/8" long and cover the entire throttle tube. Maybe your grips are shorter, as manufacturers have been cutting quality, size, and or amount in their products.
Online DoubleGuzzi
« Reply #7 on: February 09, 2025, 11:05:14 AM »
Checked today and even my cheapo £14,or so, heated grips are the correct length.
Offline SmithSwede
  • I don't want a pickle
« Reply #8 on: February 09, 2025, 01:32:29 PM »
Spackling compound
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Offline egschade
« Reply #9 on: February 09, 2025, 07:38:52 PM »
Thanks everyone for the suggestions and comedic relief.
These are full length Biltwell Renegade grips that I cut the ends off to accommodate the bar end mirrors/weights. The problem is the 'webbing' prevents me from getting the grip any farther up the tube. I'll try trimming the tube so I can move the grip inward a bit more and paint the white plastic black.
1971 Honda SL350
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Griso 1200SE Tenni
Breva 1100
EV Touring
« Reply #10 on: February 14, 2025, 11:11:46 PM »
I cut the large diameter end off the old grip and used it as a filler to cover the gap. Different bike so I don’t know if that’ll work.
Offline Bulldog9
« Reply #11 on: February 15, 2025, 08:50:04 AM »
I have heated grips on the Stornello and 1200 Sport. On the Stornello, I used a dremel to carefully trim the lip on the throttle tube, and painted the remainder black before installing the grip. On the 1200 Sport, I cut the old foam grip and slipped it over the ring as described above.
MGNOC#23231
Online blu guzz
  • Loves to ride
« Reply #12 on: February 15, 2025, 09:35:51 AM »
Duct tape.  A million and one uses.
Blue Guzz
