Author Topic: Better exhaust header gasket?  (Read 2155 times)
Offline wicks
« on: February 12, 2025, 09:59:03 AM »
Is there a better one that seals tighter in an 850 LM1 head to header? Getting a little leak on the right side after reinstalling with new gaskets. Everything is aligned and torqued properly.
'77 LM1 / '93 1000s / '73 V7 Sport / '06 Ducati Paul Smart  / '73 Porsche 911s / '94 Porsche 964 Turbo / '94 Defender 90
Re: Better exhaust header gasket?
« Reply #1 on: February 12, 2025, 03:12:27 PM »
In the 42 years I've been riding and working on Guzzis, I've never found the need for anything other than the original type.
Offline wicks
« Reply #2 on: February 12, 2025, 05:53:43 PM »
So I must have done something wrong there...can't imagine what.
Offline 73 sport
« Reply #3 on: February 12, 2025, 06:20:01 PM »
    Are they the correct size? Check for nicks or dents on the gasket. Check for nicks or dents on edge of head pipe. If problem persists, use two gaskets. I also use nickel anti seize on the gaskets.
Online John A
« Reply #4 on: February 12, 2025, 11:52:15 PM »
I snug up the headpipes first , by themselves so the rest of the exhaust system does not influence the fit at this stage. Then I mount the rest of it, gradually getting into place. I use nickel antisneeze as well and I only replace the gasket if it gets squished too thin to seal. I make sure there is no bind on the system as I massage it into place to help eliminate cracks.
Online John Croucher
« Reply #5 on: February 13, 2025, 10:45:21 AM »
Maybe the stud is pulling out of the head.  Threads stripping.
Make sure exhaust is mounted tight down stream.
Offline Stretch
« Reply #6 on: February 13, 2025, 11:09:55 AM »
Shade tree mechanic solution....  :thumb: :grin:
                                         -Stretch
1967? Change Jiang M1M
1978 Yamaha SR500
1971 BMW R75/5
1987 BMW K75S
2011 Kawasaki KLR650
2015 Triumph Trophy
Offline chuck peterson
« Reply #7 on: February 14, 2025, 10:35:21 AM »
                                         -Stretch
Ha! I was going to suggest there are two in there now causing a leak…it might take a dental pick to get them out. Smashed in there completely they can look like there isn’t one
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline bigbikerrick
« Reply #8 on: February 14, 2025, 11:07:59 AM »
This was exactly the case ,when I first got my Convert. There were 2 gaskets, and you could hardly tell, after pulling the first one out, that there was a second pressed in there tightly.
Rick.
