Author Topic: Front footpegs V7III same as Hayabusa?  (Read 3838 times)
Offline Blixten
« on: April 09, 2025, 07:02:49 AM »
Hello
Thinking of getting lowered footpegs for my V7III and found a post where someone wrote that the Hayabusa has the same fitment of footpegs as mine.
Can someone confirm this before I order random stuff of the interweb?
I have seen the Knight design ones which looks really nice but quite pricey, so looking for other options and came across these
https://www.ebay.com/itm/275432725277?var=576058748625
Offline red stripeguz
Re: Front footpegs V7III same as Hayabusa?
« Reply #1 on: April 09, 2025, 08:03:32 AM »
Those look like it should work. I have a V7 850 but I think pegs are same. Not sure about 'Busas but I know Honda CBR pegs work
2023 V7 Special
2007 Norge
« Reply #2 on: April 09, 2025, 08:06:00 AM »
I don't think I've ever heard someone bother comparing parts of a Hayabusa to a V7III.
But maybe the retailer or a Hayabusa owner can help you. What you need to know is the thickness of the pivot on the peg in question.
I quick check on my V7III (without removing the peg) suggests the pivot is 22mm thick. So that's your target.
However I'll warn you the pegs are already pretty low on a V7III so if you lower them another 25mm or so be ready to use exaggerated body English in turns or you may start scraping pegs/touching down more than you're used to.
I won't lower my V7III pegs for that reason, though I do have the Knight Design pegs on my MkI because it had a tighter rider triangle with taller pegs to begin with.
Offline Blixten
« Reply #3 on: April 09, 2025, 08:11:00 AM »
Thanks, the Busa was just mentioned in a post, but looks like the CBR are very similar as well
Offline Blixten
« Reply #4 on: April 09, 2025, 08:13:45 AM »
Thanks for checking, I´m aware about the low footpegs original, so don´t want to go further than 25 mm (1")
Offline Alfetta
« Reply #5 on: April 09, 2025, 02:45:53 PM »
dang things look pain full....
« Reply #6 on: April 09, 2025, 04:00:19 PM »
The ones I got are similar and I like them a lot better than stock. Easier to move foot around and just slightly lower to fit my long legs
https://www.ebay.com/itm/326094915656
2023 V7 Special
2007 Norge
Offline Blixten
« Reply #7 on: April 10, 2025, 03:31:50 AM »
They look quite nice, is it a bolt on fitting with spring and all to the V7?
« Reply #8 on: April 10, 2025, 08:47:03 AM »
Yes, removed spring, clip and stud from old peg, reused on new peg
2023 V7 Special
2007 Norge
Offline Vagrant
« Reply #9 on: April 11, 2025, 08:49:57 AM »
The 2012+ Honda Goldwing pegs work and are 10MM lower and much wider. After market ones are on Amazon.
Offline mechanicsavant
« Reply #10 on: April 13, 2025, 01:21:54 PM »
I was surprised to find that BMW foot pegs also interchangeable. I tried putting R 1200r pegs on my V7 , looking to reduce vibration. No major difference, so back to OEM pegs !
