Author Topic: New to me…used 2022 MG V85TT Adventure  (Read 4429 times)
Offline bobrebos1
« on: April 12, 2025, 05:41:18 AM »
I picked it up from a private seller in Lawrenceville Georgia last night and rode it home about 130 miles through Atlanta traffic etc.  I work hard so I deserve it!  I know a lot of people talk about all the bikes faults on here but I like it!  3600 miles on a 2022.  Showroom condition!  Woo hoo, congratulations to me!
fb upload
Sober, Retired Air Force!
Offline guzziart
Re: New to me…used 2022 MG V85TT Adventure
« Reply #1 on: April 12, 2025, 05:53:15 AM »
Hey Bob,
Good for you, basically a new bike for probably half the price of a new one, enjoy!
Online Clifton
« Reply #2 on: April 12, 2025, 07:43:04 AM »
Congratulations of finding such a nice example! And a yellow/white one with the cases.
25 R1300GS
21 V85TT
20 XT250
14 CB1100
08 1200R Sportster
93 R100R
Online Cam3512
« Reply #3 on: April 12, 2025, 07:48:24 AM »
Nice, congrats.  I had to buy the tubeless wheels.  2020’s came with tubes.
Offline Vagrant
« Reply #4 on: April 12, 2025, 07:49:57 AM »
Next time, let me know. We always have a spare bedroom and food.
Online yrunvs
« Reply #5 on: April 12, 2025, 08:09:14 AM »
The beautiful Giallo Mojave.
Offline inditx
« Reply #6 on: April 12, 2025, 08:17:01 PM »
Enjoy!
inditx
inditx
This is the day.....
« Reply #7 on: April 12, 2025, 09:21:21 PM »
Awesome Bob!  When are we doing a trip?
Online blu guzz
  • Loves to ride
« Reply #8 on: April 13, 2025, 07:00:26 AM »
Great looking bike.  You will enjoy it.  Now put some miles on it.
Blue Guzz
Offline tazio
« Reply #9 on: April 13, 2025, 07:34:51 AM »
My thought too ! Count me in guys, I don't mind being the 3rd wheel ! ..(or is that the 5th and 6th wheel?!) Either way, A RALLY!
Go Bob, GO! and CONGRATULATIONS.! :bike-037:
1967 Kawasaki 650 W2TT
1966 Triumph Bonneville
« Reply #10 on: April 13, 2025, 09:06:18 AM »
Way to go Bob, looks like Rt 20, not far 10mi from my place. Congrats & good luck.
Offline bobrebos1
« Reply #11 on: April 14, 2025, 03:37:35 PM »
I need to change oil, all fluids etc first thing.  Fluids on order.
Online Cam3512
« Reply #12 on: April 14, 2025, 03:41:23 PM »
Don’t overfill the rear drive.  Initially the book said 160-180 ml.  They changed it to 160 flat.  I’m working off memory here.  Anyone confirm or correct?  Does it have an aftermarket “Y” pipe?  I did that immediately, makes tranny oil change much cleaner.
« Last Edit: April 14, 2025, 03:44:35 PM by Cam3512 »
Online Trialsman
« Reply #13 on: April 14, 2025, 04:22:45 PM »
You are correct on the rear fluid level being too high and pushing fluid out onto the rear wheel.  Originally it was 180.  I checked my first V85 and it was 210 from the factory.  They then decided  160 was the proper level.  Three years later my son and I bought two more.  I took them home and drained them both.  Guess what?  They were both 180.  Obviously, someone at the factory never got the message.  While I am at it, all three never had any grease in the headset bearings until I greased them the day they got to the house.  All three have been flawless since the first day.  I bought a Stelvio figuring it would be perfect, but I still lean towards the V85.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2025 Arctic Leopard Ex-800
Offline guzziart
« Reply #14 on: April 15, 2025, 05:52:43 AM »
How involved were they to grease?  Complete knockdown and grease or just add?
Thanks,
Art
Online Trialsman
« Reply #15 on: April 15, 2025, 08:28:07 AM »
To grease the headset I put the bike on a lift and remove the front wheel.  You also should remove the calipers so there is enough room as the forks drop down.  Loosen the handlebars and roll them out of the way so you can get to the steering head nut.  Once removed, the top triple will lift off and the bottom will slide down.  I use the Belray waterproof grease and just smear it around the top of the bearing to get it packed.  I then put a coating all around the exterior and also apply a coating to the inside of the races in the head.  Reinstall and tighten to where there is a light drag on the bars turning side to side.  Install and re-torque the calipers, forks, and wheel and.............go ride.
Guzzi is not the only culprit that saves on grease.  The only bikes I have ever found to be fully packed were the several Altas that I had.
2010 FE570 Husaberg
2024 Stelvio V100
« Reply #16 on: April 15, 2025, 09:14:47 AM »
Or maybe they determined the correct amount of grease for the application.
Granted, the most miles I have put on a bike us 60,000 miles but when I have serviced the head bearings according to the service manual I have never seen rust or binding.  I also never use a pressure washer on a motorcycle.
Offline Vagrant
« Reply #17 on: April 15, 2025, 10:09:06 AM »
The rear end was changed to 160 or 5.4 Oz. But it was just reported there is a bulletin out there for the V7-850 to drop down to 130CC. I plan on using 140 from here on.
It would be nice if a dealer would confirm this.
« Reply #18 on: April 15, 2025, 01:22:20 PM »
I just HAMLIN about dropping from 160 to 130.
He has had no bulletin on that being correct.  As an aside, 160 has not caused any issues.
Talk about good dealers and PDI.  Last time I was there assisting in the shop the instruction from the boss (Jim) was every new bike was to have the rear drained and refilled with the correct amount.  Good dealers do exist.
Offline Vagrant
« Reply #19 on: April 16, 2025, 06:38:07 AM »
Thanks for checking.
Offline 9fingers
« Reply #20 on: April 16, 2025, 06:49:18 AM »
Woo Hoo is right! Enjoy!
Current bikes:
V7 Corsa - Athena
Suzuki V Strom 650 - Rita
Beta Rev 3 270
Honda TLR200 custom
Honda TL250 custom
TL250 stock
Honda TL125
Yamaha TY350
