Author Topic: HF - Apache Case for v85tt  (Read 3112 times)
Offline guzziart
« on: April 23, 2025, 04:12:06 PM »
Hi All,
I'm giving some thought to installing a Harbor Freight - Apache Hard Case to the tail rack of my '23 Travel.  I like the idea of adding 24L - 38L of low profile weather proof storage for $40-$60.  A friend of mine installed one on his CT125.  I was wondering if anyone here has installed one on their v85.
Thanks,
Art
Offline someguy
Re: HF - Apache Case for v85tt
« Reply #1 on: April 23, 2025, 04:41:08 PM »
I did a Pelican hard case on my KTM 625smc. I fabricated some slide retainers and used a cabinet lock to hold it in place rather than fully bolting down. It worked well and wasn't terribly hard to do if you are handy.
Sorry I don't have any pics. It was years ago. I really did like the feature of being able to quick and easy remove the case even though it wasn't so secure it could not be stolen. I figured if they wanted it that bad I couldn't keep them from just using a sawzall and cutting the case open anyways.
Offline izzuG
« Reply #2 on: April 23, 2025, 07:57:08 PM »
I did what you are thinking of, it worked fine.  I just found that I wanted more depth so I added a top box instead. I bolted mine down for piece of mind.
Offline LuftGansa
« Reply #3 on: April 24, 2025, 08:18:30 AM »
I did also.  That sort of box can take a hit better than the official ones.
« Reply #4 on: April 24, 2025, 08:25:20 AM »
Years ago, I bolted a small Storm Case on the rear rack of my Ducati E900.
If you don't need quick disconnect, using a Pelican-type case is an affordable and secure way to add a top case.
Offline guzziart
« Reply #5 on: April 24, 2025, 08:30:22 AM »
Hi,
Thanks for the quick responses!
Hey izzuG....Do you recall what size case you installed?  HF has a large (3800) and extra large (4800), idk if the model number refers to size but the large is about 24 liters and the extra large is about 38 liters.  Also, I like your Eldo!  I've got one of those chrome rear fender protectors too but never installed it due to interference with the rear rack,
Art
« Last Edit: April 24, 2025, 08:36:08 AM by guzziart »
Offline MGrego
« Reply #6 on: April 24, 2025, 09:45:41 AM »
I have a pelican case on my V11.  It's great, tough and watertight.  I just used U-bolts to secure it to the rack.  I found a bag made to fit the interior and I just put all my overnight stuff in there and carry it in like a suitcase.
Offline Brand X
« Reply #7 on: April 24, 2025, 11:19:43 AM »
I have been doing it for years. Latest is the Vault Boxes from Pelican,and C-bow mounts .. I have used the Givi rings,Alumimum style for quick release on certain boxes.You can get just the bow side/female for mounting any bow
you like..Rotopax is nice on the rear box top..
« Last Edit: April 24, 2025, 11:22:14 AM by Brand X »
Offline TOMB
« Reply #8 on: April 24, 2025, 11:49:16 AM »
I have the 2800 model on my Convert.
I felt that this size was the best choice for my needs.
I also  find the size and scale works as I don't get any bufiting or side push when large Trucks pass.
TOMB
« Last Edit: April 24, 2025, 08:37:11 PM by TOMB »
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Online Moparnut72
« Reply #9 on: April 24, 2025, 02:21:30 PM »
There are side cases on Ebay that are quite inexpensive. I bought a pair 2 or 3 years ago, they are $72.50 a pair. They are light yet pretty tough and are like Givi cases. I used the CBow mounts and the female bracket to mount them. I am very happy with them especially at the price.  I have a stupid Chrome Book, even though I finally figured out how to save a link I still haven't figured out how to insert it.  The easiest way to find them is to search for Segway Hard Cases being sold by InterstateBlue.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline izzuG
« Reply #10 on: April 24, 2025, 05:37:42 PM »
I had the 3800 on mine.
My Eldo had the tabs for the rear rack removed by the previous owner, so no interference issues for me.
Offline guzziart
« Reply #11 on: April 25, 2025, 10:18:51 AM »
Thanks All!
Offline guzziart
« Reply #12 on: May 01, 2025, 10:41:49 AM »
So, I bought the HF Apache 3800 and installed it on my v85.  I mounted the case on a 10" x 15" x 1/8" aluminum plate I bought for $20 at the Metal Superstore, then mounted that assembly on to the rear rack after removing the plastic foo-foo Xplate.  Mounting to the rack required shimming up about 0.410" at the four L-tabs to slightly clear the tubular portion of the rack.  I'm in hopes that those four tabs are strong enough to handle no more than the 10-12lbs of crap that I may carry in the case.  The whole thing cost me less that $100 and about 4 hours of my time, if I was 30 years younger I coulda done it in an hour!  Also, I removed the case carry handle and two side latches, their hinge pins are easily driven out from the opposite end of the pin having knurling. The $60 HF Appache case is better engineered & constructed than the hard cases that came on the Travel, imho.
Art
