Author Topic: V85 tt in the heat  (Read 3224 times)
Offline LuftGansa
V85 tt in the heat
« on: May 03, 2025, 08:48:27 AM »
Guys, I was driving the other day here in the Carolinas, and I notice that is was really getting hot.
How much heat can the V85 handle idling and for how long?
Should I turn it off when it is idling in traffic?
Rich
Online yrunvs
Re: V85 tt in the heat
« Reply #1 on: May 03, 2025, 09:35:33 AM »
Rich
If traffic is the kind where you move 15 feet every minute or so I turn mine off and push it. I'd not use the V85tt for commuting where traffic jams are liable.
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #2 on: May 03, 2025, 09:52:51 AM »
Do the bikes come with an engine temp warning? I assume that’s only good for the temperature in the block, and may not be useful for concerns near the exhaust.
« Last Edit: May 03, 2025, 10:31:30 AM by Dirk_S »
Online Cam3512
« Reply #3 on: May 03, 2025, 08:01:18 PM »
I’ve never met any air cooled Guzzi that’s happy stopped in heavy traffic on very hot days.  If you’re at a standstill, turn it off.
Online yrunvs
« Reply #4 on: May 03, 2025, 09:12:29 PM »
No.
Offline guzziart
« Reply #5 on: May 08, 2025, 06:50:14 AM »
I suspect since Guzzi nor aftermarket has made an oil cooler available, the "heat" issue must not be a problem, possibly.  However, one of my riding buds had an issue with his tube tire type v85 back in '22 when we got caught in an interstate parking lot.  I don't recall how his engine sounded at the time other than it sounded like something was seriously about to let go.  Once off the highway  and aware of the rumors of heat effects on the engine, we parked. went had lunch, came back, checked the oil level which was ok, started the bike, all was good, no nasty sounds.  The bike has been fine since.
Offline LuftGansa
« Reply #6 on: May 08, 2025, 08:37:59 AM »
Definitely worth being careful over.   I will keep these thoughts shared by you guys in mind.  The other day, I found myself in City traffic and hit the turn off switch a couple of times.
My next question is this;  Does the engine receive more wear when you turn it off for a couple of minutes and then turn it on?  Does this actually help the engine not to overheat?
Luft
« Reply #7 on: May 08, 2025, 09:42:45 AM »
In such conditions if you must ride, make sure you let the engine rev higher but with less throttle applied during acceleration phase. You will run less risk of pre ignition (pinging, detonation) if you do his.
Offline red stripeguz
« Reply #8 on: May 08, 2025, 12:00:17 PM »
I spent last summer commuting on my V7 in Texas which meant a lot of days sitting in traffic on 100* days. Never noticed any issues with the bike. Is the V85 that substantially different that heat would be more of an issue?
As a slight aside, any idea how accurate the oil temp gauge on the UpMap device is?
2023 V7 Special
2007 Norge
Offline th_01
  • It is what it is.........
« Reply #9 on: May 13, 2025, 06:38:29 AM »
I had the same concerns.  I didn't like the heat coming off the CAT under the motor on my V85.  The cat was just cooking the oil in the trans and motor.
I ended up removing the cat. I put an Agostinis's header/crossover combo, remapped and kept the stock muffler.   There was a huge drop in the heat coming off the exhaust.
This was worth the cost IMHO
Tom in MA
2022 V85 Guadia D'Onore
2023 V85 Centenario
Online yrunvs
« Reply #10 on: May 13, 2025, 07:12:08 AM »
Which map? What year bike and how does it run and sound? backfires? pops?
