Author Topic: Cast wheel refinishing  (Read 3616 times)
Offline ken farr
« on: May 04, 2025, 04:57:12 PM »
Hello All:
   I have a B1100 Breva with cast wheels.  They are factory black finish, can this be stripped off ?  If so, what are the pros/cons of then going with painted spokes and polished "rims" ?
Thank you in advance:
kjf
ken farr
06 B1100 - click!
Fillmore, Ca.
Online BMCMOTO
Re: Cast wheel refinishing
« Reply #1 on: May 04, 2025, 07:12:12 PM »
I just had a pair of Breva 750 rims powder coated. The owner of that shop said never again. It was the second pair of Guzzi wheels he powder coated for me. He had trouble cooking the oil out of them. That seems to be a standard for Guzzi cast wheels. It seems the alloy has oil included in the metal when cast. The other set were older SP five spoke wheels that he had the same problem with. Nothing to do with your situation but maybe someone else could use the info. I really could have just painted them and will next time.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
« Reply #2 on: May 05, 2025, 06:18:20 AM »
"It seems the alloy has oil included in the metal when cast."
Wow, never heard of this but I know nothing about casting metal.
Offline scra99tch
« Reply #3 on: May 05, 2025, 06:56:31 AM »
Also interested to hear what others say.  My 1980 SP1000 is a little worse for wear and the finish is peeling off.  Are factory rims Magnesium or Aluminum?
2007 California Vintage
Online AJ Huff
« Reply #4 on: May 05, 2025, 07:16:53 AM »
No such thing. And I've poured a lot of aluminum.
-AJ
'71 Ambassador
'01 California Special
'05 Road King
MGNOC# L-753
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #5 on: May 05, 2025, 07:30:03 AM »
Flung off chain lube maybe?
2002 MZ Skorpion
1994 DR Skorpion
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #6 on: May 05, 2025, 07:43:54 AM »
Tells ya what to do—get 2 gallons of oven cleaner, a couple beers, and go to town on that powder coat while rocking to Pavarotti’s cover of “Free Bird”. Deterioration to the aluminum from the oven cleaner won’t matter because you’re painting over it.
<jokes> </jokes>
« Reply #7 on: May 05, 2025, 08:24:13 AM »
Not magnesium.
FWIW: Mark @ Moto Guzzi Classics uses "SEM 39283 Lite Titanium Bumper Coater Aerosol" to paint Guzzi cast alloys. https://www.amazon.com/dp/B000HB0LHO
« Last Edit: May 05, 2025, 11:23:17 AM by Antietam Classic Cycle »
Online BMCMOTO
« Reply #8 on: May 05, 2025, 08:28:03 PM »
I know little about cast aluminum or any other casting processes and was repeating what the technician told me. It does seem a bit ridiculous to me now. I just know he had problems. Definitely not from a chain driven bike. One big block Guzzi and one small block Guzzi. I just know that in the future I will be painting wheels to change their color.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline SIR REAL ED
« Reply #9 on: May 06, 2025, 06:40:36 AM »
Brian
Very strange indeed.  I have had Suzuki cast wheels powder coated with no problems whatsoever.
Personally, I would consult another powder coating shop rather than put much stock in what you were told.
While powder coating is very durable, the plus side of paint is it is very easy to touch up.
Good luck!
2002 MZ Skorpion
1994 DR Skorpion
Offline paulbricey
« Reply #10 on: May 06, 2025, 12:36:39 PM »
My V65 Florida wheels were badly corroded (& tyres had to be cut off them) after 20 years stored in the rain. I stripped the paint (lots of corrosion under the paint) & instead of powder coating I decided to just have them Vapour blasted before fitting new bearings & tyres. They are easy to keep clean, no paint to flake or ding, don't seem to corrode (3 years so far) & I actually prefer the 'naked' metal look.
Riding to live
