Author Topic: Head Gaskets  (Read 1489 times)
Offline GuzziNZ
Head Gaskets
« on: May 09, 2025, 03:20:42 AM »
Concerning my 850T with Gilardoni  cylinders.
It looks like I should use the cylinder head gasket with the oval holes for the push rods.
Does anyone know the brand of full gasket sets that come with these gaskets?
Re: Head Gaskets
« Reply #1 on: May 09, 2025, 08:20:22 AM »
The only (top-end) gasket kits that I know of that come with the oval hole head gaskets are those sold by MG Cycle. There might be others, but I've never seen them.
Offline GuzziNZ
Re: Head Gaskets
« Reply #2 on: May 12, 2025, 06:10:07 AM »
Someone said you don't need the oval hole gaskets but I find it hard to imagine that the round hole gaskets will work on the Gilardoni's.
Re: Head Gaskets
« Reply #3 on: May 12, 2025, 06:39:54 AM »
You can't look in pushrod holes & figure it out?  Make gaskets out of paper, place heads on & assemble them to snugged up, rotate motor, disassemble and look at the paper w/round holes. See if pushrods have touched the paper. This will tell you what you need.
Re: Head Gaskets
« Reply #4 on: May 12, 2025, 08:39:23 AM »
If the holes in the cylinders are oval, then the oval holed gaskets should be used. The round hole gaskets won't seal around the pushrod tunnels as well.
