Author Topic: Bonding Steel to Aluminum (solved with a hockey puck)  (Read 8671 times)
Offline SIR REAL ED
  • uh.... it's personal....
Re: Bonding Steel to Aluminum (sort of solved)
« Reply #30 on: May 22, 2025, 05:27:53 PM »
Could be.. Just at the right spot!
Serendipity!
2019 Beta EVO 250
Offline John Croucher
« Reply #31 on: May 23, 2025, 06:25:49 PM »
I drill two holes in sidestand pad.  Made an aluminum extension.  Drill two holes and threaded in aluminum extension that lined up with sidestand holes.  Attached extension to sidestand with screws.  No glue.
Offline willowstreetguzziguy
« Reply #32 on: May 23, 2025, 07:27:51 PM »
Any pictures?
2008 Guzzi 1200 Sport
Offline Perazzimx14
« Reply #33 on: May 24, 2025, 07:00:14 AM »
I just used a $3 hockey puck and two 10-32 screws. Total cost $4 and I got a 1" rise and a 3" diameter fad so the bike does not sink into the earth when parked on drit/grass/gravel.
« Last Edit: August 16, 2025, 08:34:50 AM by Perazzimx14 »
Offline Moparnut72
« Reply #34 on: May 24, 2025, 08:49:44 AM »
I did the same thing two days ago. Much better so much easier to mount the bike from the peg without the bike leaning over so far. The Mandello manual cautions against putting excessive weight on the side stand. So with the bike being more vertical the weight on the stand is reduced especially with all my excessive camping gear on the bike.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #35 on: May 24, 2025, 12:00:42 PM »
I similar bought a hockey puck recently for my V7 III after installing the NTX forks and 21” wheel. The best part is—our bikes are now officially sanctioned by the NHL. Ready to hit the ice, just need the studs/screws!
« Last Edit: May 24, 2025, 12:01:15 PM by Dirk_S »
« Reply #36 on: June 07, 2025, 08:17:51 AM »
After testing my new sidestand on asphalt and then on gravel, it failed in gravel. The double face tape, no matter how strong it is can’t hold up to the sheer forces exerted upon it. So I ordered a hockey puck, got the right taper bolts, and nuts, and with some drilling,cutting and JB weld I finally solved it. Thanks for the hockey puck idea.
« Last Edit: June 07, 2025, 08:26:08 AM by willowstreetguzziguy »
