Author Topic: Old Eldo blowing oil out thebreather tube  (Read 1877 times)
Online Tkelly
« on: May 21, 2025, 01:21:05 PM »
A friend started his old bike for the first time in a few years and it blew out about a quarter quart of oil thru the breather tube.Any suggestions ?I think it is a 73 Eldorado.
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Old Eldo blowing oil out thebreather tube
« Reply #1 on: May 21, 2025, 01:22:56 PM »
Water accumulation via atmospheric fluctuation?
Offline moto
  • Fear the deer!
« Reply #2 on: May 21, 2025, 02:59:55 PM »
Right away? Or over a ride of X miles? (X=?)
850 T-3
Griso 1100 corretto
Online Tkelly
« Reply #3 on: May 21, 2025, 03:07:40 PM »
Didn’t say,what are the likely causes in each situation?
« Reply #4 on: May 21, 2025, 03:39:50 PM »
Stuck flap or disc on pin w/spring in the box on block. New box used to be $25 that was awhile back. I don't trust old ones.
Online jhem68
« Reply #5 on: May 21, 2025, 04:27:04 PM »
Always an outside chance of gas seeping past the float and migrating into the sump if the petcock leaks or was left in the on position, so hopefully he checked the oil level before starting it up.  But most likely the flapper is stuck shut as Steve suggested.
John H
Online Tkelly
« Reply #6 on: May 21, 2025, 04:57:08 PM »
He traveled to MG and they gave him advice on how to clean the flap in the box.Thanks for the tips.
Online michaell32
« Reply #7 on: May 21, 2025, 05:04:51 PM »
If it was sitting for years there could be rust on the cylinder walls not allowing the rings to seal as well as they should.  Compression leaks past the rings and builds up excessive crankcase pressure.
2003 California EV
2018 Suzuki DR650
78 Honda GL1000
« Reply #8 on: May 21, 2025, 06:27:57 PM »
Deteriorating chrome bores?
Eldorados had chrome plated cylinder bores from the factory and the chances of that flaking off are good. If it was fitted with aftermarket iron liners, then rust could be an issue.
