Author Topic: Dyna S in a v50iii  (Read 2385 times)
Offline GuzziV50
Dyna S in a v50iii
« on: May 25, 2025, 08:29:21 PM »
Does anyone know if the stock mechanical advance unit is used when installing a Dyna S  in a V50iii?
Thanks much!
Offline Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
Re: Dyna S in a v50iii
« Reply #1 on: May 25, 2025, 08:49:13 PM »
Yep—I installed one on a Lario last year. The quick description from their webpage states:
The Dyna S is completely housed behind the ignition cover and uses a magnetic rotor with the original spark advancer, so the factory advance curve is maintained.
You can also download the instructions from their website:
https://www.dynaonline.com/dyna-s-ignition-system-for-1979-1987-moto-guzzi-v35-v50-v65-1/?srsltid=AfmBOoolHvyIOCtC5qFEP7nGZqTerlLwZPNXeh75bpmnKOIrxl29KIfH
« Last Edit: May 25, 2025, 08:49:53 PM by Dirk_S »
Offline pehayes
« Reply #2 on: May 26, 2025, 12:42:37 AM »
Yes.
And because it is exposed to the air and the dust discharge from the front wheel they system requires annual disassembly, cleaning and lubrication.
If you mark the Dyna-S carefully you can remove and reinstall without altering the ignition timing.
Caution:  The magnetic rotor can be installed TWO ways and only one way will run the engine.  Mark carefully before you disassemble.
Offline paulbricey
« Reply #3 on: May 26, 2025, 05:42:59 AM »
Pics on V50 III shows adv & then Dyna S on top. I love Dyna S compared to points BUT be careful to use 'quality' coils (OEM ones are good generally, but aftermarket resin ones maybe less)....one of my aftermarket 4 ohm resin coils went south/burnt out & blew out the associated Dyna S unit on the plate. I had to buy another Dyna S and replaced the coils with lucas metal ones...no probs since.
Riding to live
Offline Pescatore
« Reply #4 on: May 26, 2025, 09:53:23 AM »
It's discounted a few bucks now.
I guess it's solid state switches, so no more spark nor condensers needed.  One less thing to worry about.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline moto-uno
« Reply #5 on: June 01, 2025, 09:34:48 AM »
  That has to be the peak of irony , replacing failed coils with British Lucas coils  :grin:
