Author Topic: 40mm Bitubo adjustable fork dampers  (Read 3472 times)
Online Turin
« on: May 26, 2025, 11:43:43 PM »
One of the fork dampers on my 1991 cal III is locking up. Contributed to a scare Saturday morning.
I need at least one new damper. Here's the rub, I want to keep the adjustability of the stock dampers (the nifty dials on top , don't want the air valves)
Options? damper kit? NOS parts?
« Last Edit: May 30, 2025, 01:08:05 AM by Turin »
1985 Sidlow Guzzi
Online Turin
Re: Bitubo adjustable dampers 1991
« Reply #1 on: May 27, 2025, 12:11:48 AM »
« Last Edit: May 27, 2025, 12:19:02 AM by Turin »
1985 Sidlow Guzzi
Online PeteS
« Reply #2 on: May 27, 2025, 06:54:21 AM »
This happened on my ‘76 Lemans. Almost no fork travel. I drilled the caps for schrader valves to let the trapped air out.
I planned to switch to FAC but still looking for a round tuit.
« Reply #3 on: May 27, 2025, 08:32:24 AM »
Same thing happened last year to the dampers on my Cal III FF. I searched for rebuild parts, or complete dampers without success. Ended up installing FAC dampers.
« Reply #4 on: May 27, 2025, 08:41:08 AM »
Have you tried Harpers?
Online Turin
« Reply #5 on: May 27, 2025, 09:08:24 AM »
Curtis is usually my first call. Be trying that shortly.
1985 Sidlow Guzzi
Online Turin
« Reply #6 on: May 30, 2025, 01:07:04 AM »
saw an old thread about rebuilding dampers on the adjustable bitubo forks. ( bitubo rebuild kit #gr0024 )
https://wildguzzi.com/forum/index.php?topic=89277.0
1985 Sidlow Guzzi
Online Turin
Re: 40mm Bitubo adjustable fork dampers
« Reply #7 on: July 20, 2025, 04:18:11 PM »
This is wrapped up. I bought two kits from Harpers. (turns out one kit does both fork tubes) The new pieces have two O-rings on each aluminum insert vs one.
1985 Sidlow Guzzi
« Reply #8 on: July 21, 2025, 06:43:33 AM »
Hmmm....I should probably contact Curtis and see if he has another kit as I assume it will be impossible to find this in the future.
