Author Topic: Stelvio 1200 NTX ECU map needed  (Read 3638 times)
Offline whitewolf
« on: June 03, 2025, 02:21:50 PM »
Could someone please share a 2014 Stelvio 1200 NTX 4V ECU map for a 5AM ECU? I can share mine in return, idle is not working well but you get very nice backfires on deceleration :)
I have the idle issue described on this thread here https://wildguzzi.com/forum/index.php?topic=123163.msg1902114#msg1902114
Meanwhile I got idle choking when the engine is first started and cold, so usually I need to start the motorcycle several times until it runs. Checking older threads and online data I've found many people reporting this issue resolved after writing a new map.
Re: Stelvio 1200 NTX ECU map needed
« Reply #1 on: June 03, 2025, 02:54:39 PM »
Online Tom H
« Reply #2 on: June 03, 2025, 05:24:47 PM »
You might look up about cleaning your stepper motor. It can cause idle issues.
Offline whitewolf
« Reply #3 on: June 04, 2025, 12:51:18 AM »
http://www.griso.org/
Thanks, I know this site, but if I'm going to pay $100 I'll go to a Guzzi shop, buying an ECU map from over there may not fix my problem and I'm not looking for tuning the bike, I'm hoping someone with a similar Stelvio can just pull out the map and share it
that's something I didn't tried, thank you, I'll check the stepper motor
Online Tom H
« Reply #4 on: June 04, 2025, 09:25:03 AM »
Beetle maps fix some of the issues with stock Guzzi maps.
You can cycle the stepper just by turning on the key for a moment and then turning it off. You will hear it moving.
