Author Topic: The Guzzi Virus Spreads: V50 II  (Read 26207 times)
Online DoubleGuzzi
Re: The Guzzi Virus Spreads: V50 II
« Reply #30 on: September 11, 2025, 06:20:13 PM »
In other news..
I took advantage of the rare warmer weather here, though still plagued by a coastal breeze, to respray the sad looking front mudguard.
First, I carefully used a craft knife to get samples from the flaky paint on the mudguard and a little from the left sidepanel. Popped into a used bag, backed by some thin cardboard, I sent these off in an envelope to one of the UK-based paint suppliers. (Just FYI: EH Factors - relatively expensive but superb customer service, so worth it!)
The closest match they suggested was (Alfa Romeo/Fiat) Azzurro 437B and though I was a little sceptical (having read through numerous internet posts where it was mentioned only once), I reckon it's a very close if not perfect match.
Wasn't the best rattle can job that I've done - there's an annoying run that I may tackle at some point - it turned out better than I anticipated. I had some dregs left over, so masked off the decals etc. on that sidepanel and gave it a quick coat. Sorry no pics and it was just a nasty cover-up job. :embarrassed: If I end up going to the expense of getting a decal set, then I may do a 'proper' respray job (health/wealth/weather permitting).
« Last Edit: September 11, 2025, 06:36:47 PM by DoubleGuzzi »
Nearly natural progression..
Online DoubleGuzzi
« Reply #31 on: September 11, 2025, 06:24:18 PM »
« Reply #33 on: September 11, 2025, 09:22:34 PM »
The V50 is that the one with heron heads and 4v/cylinder aka Lario
I had one of those for a while but I was glad to Off Load it.
« Last Edit: September 13, 2025, 01:09:14 PM by Kiwi_Roy »
Online Dirk_S
  • www.dirkshearer.com
  • Doodler of doodles
    • www.DirkShearer.com
« Reply #34 on: September 11, 2025, 09:28:19 PM »
I had one of those for a while but I was glad to off road it.
The 4 valve small blocks were the V35 Imola II, V50 Monza II, V65 Lario, and later the V75.
Not the same as the V50 I / II / III. Also, the 4-valve heads weren’t Herons. The heads were dished, and I think it would be considered a bathtub style combustion chamber?
« Last Edit: September 11, 2025, 09:30:35 PM by Dirk_S »
Offline paulbricey
« Reply #35 on: September 12, 2025, 07:12:20 AM »
In my experience the exhaust system is always tricky to fit (V65 Florida & V50 in my case)....I had all sorts of problems with angles/clearances etc on both, but ultimately seems slacking everything & redoing it in a way that sort of  'locks bits in certain places' is the way to go eg Tighten everything/use straps to hold the silencer in place, then bugger about with headers & link pipe (& then try it a different way when that doesn't work) !!
I fitted a 650cc engine in the V50-3, so this added to the difficulty of lining up the original V50 system - headers are about an inch higher up....but somehow it did fit w/out leaking exhaust. F
or the wheel axle on V50, the silencer runs LOW enough that it never hits (you can see from pic the wheel is still above centre of silencer even on main stand - even more clear when I sit on it w/out stand). For the V65 Fl it was even harder as rear axle centre IS in line with upswept exhaust & clearances are 'nominal'. Again it works with straps/woodworking clamps & trial-and-error, but still looks worrying close !
Paul
« Last Edit: September 12, 2025, 07:13:40 AM by paulbricey »
Riding to live
Online DoubleGuzzi
« Reply #36 on: September 12, 2025, 12:46:49 PM »
I managed to squeeze the new stainless clamps onto the silencers, just. They've tightened up well.
I have the right silencer fitting fine now - might even get a socket onto the spindle nut.  :smiley:
The left side is impeded by the sidestand spring stub as well as the sidestand itself - I can't rotate the header outwards without the gear lever hitting it. I have levered the silencer outwards a tiny bit and compromised by adding washers between the silencer and its footpeg bracket. It doesn't touch now when on the centrestand and both silencers now sit at (close to) the same height.
I can live with this.
Offline paulbricey
« Reply #37 on: September 13, 2025, 04:39:27 AM »
Sounds right  :wink:  My gearlever barely misses the header on downshift (somehow no marks on it); for my brake lever could just about fit a fag paper between it & header when pushed down. Tighter tolerances on exhaust fitting that most of the engine parts !
Riding to live
Online DoubleGuzzi
« Reply #38 on: October 27, 2025, 10:51:53 AM »
Winterised!
Handguards (in addition to my usual heated grips) and a taller (Puig Plus) screen, that I had removed from the Street Twin as soon as it arrived.
There's a pair of mini LED spot/fog lights lurking under the bottom yoke. I swapped out the Chinese headlamp from the Breva, replacing the Cibie with distorted shell. (The Breva now has a V7 headlamp from my Shiny - 'cos I sourced a cheap one in better condition.)
The missus doesn't approve of my idea of fitting DIY leg shields, for some reason.  :thewife:
Unrelated. The grabby clutch seems to be settling down, thankfully. Perhaps the bike had been sitting unused for extended periods and rust(?) is now being shed, along with friction material. I was considering flushing out the the clutch area with brake cleaner, as suggested in some forum posts - think I'll take a rain-check or more, on that idea.
As a matter of interest, the rev counter approaches the yellow mark in top at approx. 80mph showing (closed circuit, officer) which gives the impression that the clutch may be slipping but it doesn't 'feel' that way. Extrapolating revs to the red line, which would need a long downhill stretch of road, the bike theoretically couldn't reach three figures. Not that I'd want to hammer the poor old thing to that degree and not the purpose of buying it!
« Last Edit: October 27, 2025, 11:26:52 AM by DoubleGuzzi »
Online Dirk_S
« Reply #39 on: October 27, 2025, 12:18:15 PM »
I’d try harder; throw in some trade bait. I liked the leg guards on my Ural and think the guards on the old small block police bikes look the business.
I got way too excited when I saw leg guards on the V7 II Alce concept years back.
