Author Topic: one shock inverted.?  (Read 3512 times)
Offline bacongrease
« on: June 08, 2025, 10:27:06 PM »
  Shocks.  Only one inverted?
 What is the advantage of inverting only one rear shock. ?  2004 Stone Touring.
 PO had the bags off.
 :undecided:
« Last Edit: June 09, 2025, 07:25:07 AM by bacongrease »
Online Vagrant
Re: one shock inverted.?
« Reply #1 on: June 09, 2025, 06:13:11 AM »
Drunk when installed. Can’t wait to see what you find next.
Offline Alfetta
« Reply #2 on: June 09, 2025, 07:43:53 AM »
if the shock is only adjustable on compression, flipping one over offers rebound adjustment.
as shock equipped with both are a bit pricey...
Offline elrealistico
« Reply #3 on: June 09, 2025, 08:38:02 AM »
Never heard of this, seems like some sort of red-suspender old wives tale, how's that work with the stock EV shocks?
2018 V7III Special
1978 T140V Bonneville
2004 EV Touring
Offline bacongrease
« Reply #4 on: June 09, 2025, 09:41:20 AM »
 Apparently Works Performance shocks.  I don't know which model.
and a rebuild is necessary as they are leaking.  :cry:
« Last Edit: June 09, 2025, 09:42:02 AM by bacongrease »
« Reply #5 on: June 09, 2025, 10:04:13 AM »
ROFL!  You should've saved this one for an April 1st joke.
Online DoubleGuzzi
« Reply #6 on: June 09, 2025, 10:16:50 AM »
.. there's a steel ball inside the damper rod, that blocks off the lower rebound section: flip it over and the compression section gets blocked. Possibly. Patent pending. :evil:
« Last Edit: June 09, 2025, 10:20:37 AM by DoubleGuzzi »
Nearly natural progression..
« Reply #7 on: June 09, 2025, 10:29:53 AM »
I’ve seen it on Earls front forks. 99 on EV ‘s have one front leg rebound and one leg compression damping. It’s used on off road buggies as well.
« Reply #8 on: June 09, 2025, 12:03:38 PM »
So do a lot of other bikes.  Not the same as mounting upside down.
Offline wirespokes
« Reply #9 on: June 09, 2025, 02:29:57 PM »
If the shock will work upside down I can see it. Clever idea - but looks wonky, I'm sure.
Offline ridingron
« Reply #10 on: June 09, 2025, 06:32:45 PM »
Good luck with that!
