Author Topic: Guzzi Diag Reader .bin file  (Read 3200 times)
Offline vrdennisj
  • Den
  • Ride, whenever you can get away with it.
« on: June 11, 2025, 09:59:23 PM »
I have a 2014 California Touring and I've successfully read the map file into a .bin file.
My question is:  How do I view the contents of that .bin file.
I've seen references to using another application tunepro, I guess I could try that but is there another way?
Also, I have downloaded the 7SM_MotoGuzzi_1400_ EURO4_V1.04.xdf file, but I don't know if this file might help me. I don't know how to use it.
Any help would be much appreciated, Thanks.
Den j.
1973 BMW R75/5 (beloved)
1978 Suzuki GS 1000 (still kicking)
Offline averb
Re: Guzzi Diag Reader .bin file
« Reply #1 on: June 12, 2025, 12:45:54 AM »
Tunepro is the way to view the file - it's free
Steve
Offline Kjon
« Reply #2 on: June 12, 2025, 03:32:41 AM »
Yep, Tuner Pro is the way to go. However I think you have the wrong XDF file. With your bike being 2014 you almost certainly need the EURO 3 version. EURO 4 Applies to post 2017 vehicles.
Jon
« Reply #3 on: June 12, 2025, 07:42:56 AM »
TunerPro is the only way to go.
The XDF file configures TunerPro for the type of BIN file you have. Make sure you have the correct one.
« Reply #4 on: June 12, 2025, 08:16:49 AM »
You have to apply the bin file and map file to TunerPro to see or modify your map Guzzidiag only installs it or retrieves the map to a file.
You need to read the thread about GuzziDiag & TunerPro it's all in there if you read.
Offline vrdennisj
  • Den
« Reply #5 on: June 13, 2025, 09:22:47 AM »
Thank you kindly Jon, Wayne and Steve for you informative responses. You've answered all of my questions and I'll access the guzzidiag & tunepro thread, to get a full understanding of what (and how) I'm doing this. You guys are very helpful and swift to respond, much obliged.
BTW, I'm a decades long linux user (and programmer) and although I did initially use it with my Dell Latitude laptop and found GuzziDiag to work to a degree, I loaded MS Windows 10 since it seems to be the only platform that supports the PROM reader application. In the end, my only stumbling block was the connection cables. Once I purchased the recommended cables everything else ran smoothly.
I'm exceedingly grateful to this WildGuzzi community for all their support. You guys are GREAT.
Den j.
